Question about HP Pavilion M90 Monitor
I can only get 480 x 640 resolution and 4 bit colors and all the graphics are fuzzy
  • HP Master
  • 32,281 Answers
It appears the graphics card driver has not been installed. Check the device Manager and if you get a yellow ? against the Display Adapter then you need to install the graphic driver.
If your computer is a Compaq or HP then you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
If your computer is not a Compaq or HP desktop computer and you know the make and model of the graphics card in your computer then go to the graphics manufacturer's WEB site to download the graphics driver.
Posted on Oct 01, 2009
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
It only displays 4bits
If your computer monitor displays 4 bit color and a resolution of 640X480 and you cannot increase the color bit and the screen resolution then the display graphics card driver was not installed or the wrong graphics driver was installed.
Install or re-install the correct graphics card driver.
Nov 18, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Pc to projector fuzzy as hell, all diff resos.
Well the ax-100 can only display 1280x720. If you output anything different - lower or higher - the image needs to be rescaled, which inevitably makes it a bit fuzzy.
May 29, 2009 | Panasonic PT-AX100U-EC DLP Projector
Animated resolution and 4 bit color quality
go to the support site for your computer and download the graphics drivers from there then you can switch it
May 27, 2009 | Compaq Evo D300s (269124-051) PC Desktop
Lost my 32-bit color resolution
if its a stock system with out upgrades can go to
HP select your OS then select graphics
Apr 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Mar 16, 2009 | Computers & Internet
Screen resolution of 1080p sharp lcd
set the resolution to the native resolution of the monitor
less makes it look fuzzy
Dec 31, 2008 | Best Data Products Best Data BizView BV200...
HP Pavilion M90 Monitor Logo
123 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
