Question about Toshiba Satellite L305D-S5895 Notebook
My Satellite L305D-S5934 Screen is Dark but sound like my laptop in running normally
  • Toshiba Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Oct 01, 2009
Where is the CMOS battery located
Battery of this new notebook should need be replaced at this time. But other info and support from manufacture can be found at
Satellite L305 S5934
May 25, 2014 | Toshiba Satellite L305D-S5934 Notebook
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Toshiba.satellite.L305D-S5934.blank.screeen.fan.running.will.go.no.further.than.that.Happened.a.few.weeks.ago.and.after.holding.down.power.button.and.taking.out.battery.numerous.times.it.worked.for.5.weeks...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 03, 2011 | Toshiba Satellite L305D-S5895 Notebook
When I turn on my laptop the screen stays dark but everything else works got a sloution?
Most probable cause for this is a broken backlight or a bad inverter, both of which are hardware parts that a service person can replace.
Jul 11, 2010 | Toshiba Satellite L305D-S5934 Notebook
I have a toshiba satellite L305d-S5934 laptop and when i turn it on all i get is a black screen and sound from when its coming on but nothing shows on the screen how can i fix that
Look carefully at the screen, you should see some very faint images while its booting up. IF this is the case you need to replace the inverter.
Mar 13, 2010 | Toshiba Satellite L305D-S5934 Notebook
My Toshiba laptop suddenly
Dear
you have to uninstall the sound driver , by going to device manager , and then uninstall the audio and also uninstall realtek or whatever you have software installed , and then try a new download and install it good
if this didnt work dont be sad i have the best solution but first you have to do this
Jan 19, 2010 | Toshiba Satellite L305D-S5934 Notebook
Toshiba satellite L305d-s5934 has built in webcam only i can view my own image when i'm o yahoo messenger. person i'm talking to can't see me, jus black screen. camera comes on just fine but no one can see...
try to change the video setting if it's not work try to use a SKYPE chatting program and check with any one of ur friends if it works then ur yahoo messenger is faulty
Jun 09, 2009 | Toshiba Satellite L305D-S5904 Laptop
Toshiba Satellite L305D-S5895 Notebook Logo
783 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
