Food Processors
Problem for Cuisinart Food Processors
Generic problem for all Cuisinart Food Processors
When i try using it, nothing happens. i can...
By drydoc0007 on Sep 30, 2009
Cuisinart food processor DLC-10
when i try using it, nothing happens. i cannot find my instruction manual. everything is locked in place. can you help? thanks
Solution #1
posted on Oct 01, 2009
Not Rated)
ThaMp3Doctor
Rank: Guru
Rating: 86%, 4698 votes
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Was this helpful?
Yes
No
Popular Solutions for Food Processors
Questions and Unsolved Problems for Food Processors
Answer
does any one have a disk carrier (hole in top of shaft) for a Braun food processor type 4259?
Answer
I would like an operational manual for the "Power Chopper"
Answer
I have a Moulinex La Machine Food Processor LM2. The chopping blade has cracked where it lasy on the... (More)
Answer
I have a sunbeam multiprocessor . I recieved it over 12 months ago and used it for the first time... (More)
Answer
looking for owners manual for GE food processor cat. no. D1FP2-4202
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Food Processor Experts
Top Small Appliance Repairmen
(316) 283-4211
Cuisinart
(316) 283-8664
Cuisinart
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
