Question about SanDisk Sansa Clip MP3 Player
Can I use my RIM charger to charge my Sansa Clip from a.c.? Input 100-240V a.c. 50-60Hz 0.2A Output 5V d.c. 0.7A The plug is the same as the UBS cable that came with my "Clip" Jim T
    President:
  • 803 Answers
It will work
Posted on Oct 01, 2009
Testimonial: "Response was to the point and timely."
Battery does not want to charge
Could be variable reasons -> If you're using generic brand chargers or charger adapter (these have various voltage settings on them and numerous tips for insertion into charging location on unit). This is often an issue with regular cell phones as well. If you don't use the same brand charger (or at the least, one of the reputable 3rd party manufacturers, ex: Belkin)...Most importantly, make sure the charger output matches input of the phone. If you're unsure, check you owners manual for specifications. Do the same for your charger specification. If it's quicker to use the internet. Search the net for your phone model. This also includes the info you need for the charger...Depending on the age of the battery and/or the tablet/e-reader. Again, there could be many variables
Apr 26, 2015 | Tablets & eReaders
Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
Aug 25, 2011 | SanDisk Sansa Clip MP3 Player
I tried to charge my sansa clip with an ipod mains charger and now it is dead!
You can try and reset your sansa and see if this fixes the issue.
Connect the proper USB cable to yoru Sansa the Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Without a panasonic SDR-S7 charger...
Before connecting the charger keep these in mind: volts current in amperes, polarity. If anything goes out of range your camera may burn out. Don't try a 'min' or 'max' just use the exact charger ratings. In electronic stores there are these variable adapters available on which the output can be varied. Get one of those, they are cheap and you can use them to charge multiple items.
Aug 07, 2009 | Panasonic SDR-S7S Flash Media Camcorder
My SanDisk Sansa Clip won't charge, it say's it's connected with the charging bar moving quickly back and forth
If you've used the player while hooked up to the charger this often kills the battery and you will need a new one.
Never use a phone or battery operated device through the charger. Always just let it charge!
Has it held a charge before?
Jack
Mar 08, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk, 2 GB Sansa mp3 player won't charge
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
Oct 17, 2008 | SanDisk Sansa e260 MP3 Player
Wallcharger for Sansa CLIP...
Get a USB wall charger - one end plugs into the wall, and it contains a USB port. Readily available from Walmart, Target, etc. I would recommend the Sansa specific one, available at become.com:
USB Ac Charger Sandisk MP3 The Macally USB AC charger is a USB power adapter you can use to charge your Sansa MP3 Player at home, on the road, or whenever your Sansa is not ... Read More
$18.99 - $19.99 at 3 stores
Jun 18, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
