Question about ASUS A7V8X Motherboard
Computer boots to BIOS screen
Recently my wife's computer started booting up to the BIOS screen with a message that the CPU speed was wrong (it wasn't) or the memory speed was wrong (it wasn't). The time was not being maintained. I replaced the motherboard battery but that didn't help. It seems unlikely that the recently purchased battery is bad or that it is improperly seated (it is held in place with a clip). Any other suggestions.
  • apteryx Dec 21, 2007
    The settings are saved automatically when I exit the BIOS screens. Upgrading the BIOS is more complicated by the instructions. The easy way, ALT-F2 during POST doesn't work. Using the Aflash utility and the file that ASUS says is the current revision (in the process I found out that the motherboard is not an A7V8X but an A7V8X-X and some update files are different) the process rejects the new BIOS as being the wrong file size. The update option is to update BIOS without Boot Block and ESCD. I figured that with those options, it might accept a larger file. However, the instructions to include those options say to "hold down the [2] in the main menu and also key". Since the absence of the "key" to hold down is critical (I don't thing there is an "also" key), I was not able to access the option.
    Thanks for trying though.
  • apteryx Dec 31, 2007
    Sorry, I have been away for a week. ASUS finally responded to the typo in its instructions. However, your last suggestion seemed to fix the problem (or it went away for some unknown reason). I could not find any difference in the BIOS after loading the defaults except for the splash screen being turned on. There were no adverse effects when I turned it off. Take credit for this one anyway. My wife is satisfied that her computer boots up normally and I am not going to worry about upgrading the BIOS.
    Thanks for your help.
    Scholar:
  • 102 Answers
Apteryx:
Did you try loading the defaults in the BIOS? make sure that you save the changes while exiting BIOS.
-You might also need to install any updates of BIOS on this particular motherboard (going to the manufacturer website of the motherboard will be helpful).
Let me know please.
Hope that helped!
Posted on Dec 20, 2007
Bios speed slow fast karni hai
First of all, your computer must be completely powered down and turned off before starting this process. You won't be able to edit the BIOS in sleep mode or hybernation mode. Next, power on the PC and enter the system BIOS. How you enter the system BIOS screen will vary according to your computer's manufacturer. This usually involves a series of keystrokes. Which keys are used will depend on your system. Now that we are in the BIOS screen, we are ready to speed up Windows XP boot time. Find the Boot menu and select it using the arrow, Tab and Enter keys on your keyboard.In most systems, you'll find a Quick Boot option. Enabling this will skip common system self tests that occur automatically when the computer is powered up.
In the next step to speed up boot time, look for the Boot Device Priority option. You should change the first boot device to your hard drive. This will speed up boot time, but won't allow you to boot via a boot disk like CD or floppy. If you make this change, then need to boot from a disk later, you can re enter BIOS and change it back. Next, choose the option Exit and Save Changes and the computer will restart.
Always Remeber to do this process carefully because a wrong action will cause destruction and make your computer useless.
Dec 04, 2010 | IBM ThinkCentre 8172 Intel Desktop PC -...
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
You have to wipe bios to make it boot set bios upturn off.you have to wipe bios again to start up again.
This indicates you have something set wrong in the bios. Check your clock speed and match it to your cpu.
Dec 19, 2009 | MSI K8MM-V Motherboard
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Sep 08, 2009 | E-Machines T6528 PC Desktop
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
D195GAV
Check the BIOS settings to see if CPU is set correctly at the proper speed etc
Sep 11, 2008 | Computers & Internet
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
BIOS DISPLAYING INCORRECT CPU SPEED
Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Soltek SL-75FRV Motherboard
ASUS A7V8X Motherboard Logo
215 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
