Question about Craftsman 25cc Gas Line Trimmer
Starter recoil spring got away from me - Craftsman 25cc Gas Line Trimmer
  • 279 Answers
There should a metal item that the spring fits into. It will be one with a hole through and have a lip around with part of the lip missing. You have to figure which way the spring goes, then put the end of the spring into the metal part. What I did was to hold the metal part in place with one hand and turning the spring with the other. All this was done while the metal part was laying on the work bench. Once you have wound all of the spring onto the part, it will stay in place. Be careful and good luck...Lee
Posted on Oct 01, 2009
HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
Starter pull rope does not rewind spring broke how to tear down
How to Rewind Recoil Starter Spring Quick Fix This page also has videos explaining how to remove and replace the cover with recoil spring.
Sep 01, 2014 | Polaris Scrambler Men's Mountain Bike
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How to install recoil spring
    Remove the starter cover, with the cover off remove the centre fixing screw in the plastic pulley, remove the pulley, be carful that the old spring does not fly out, new starter springs will be in a keeper, place the it into the cover make sure the looped end is located onto the anchor point in the cover, push home and take away the keeper, re fit the pulley and securing screw.
    Jun 01, 2011 | Husqvarna Chain Saw Chain 16"
    Starter recoil spring reload, How?
    If the spring is unwound.
    Recoil Spring Rewind
    I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
    If the starter cord needs a pretension, this works quite well.
    R² Starter Rope by SmallEng.com
    http://www.youtube.com/watch?v=eRyy3MlsjVo
    If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
    Lou
    Mar 26, 2010 | Homelite Garden
    WeedEater Edger PE550 Starter Rope will not recoil
    Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
    Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    THE STARTER REWIND SPRING IS BROKEN
    you can not fix recoil spring all you can do is replace it.never said what the recoil is on so cann't help till you tell what it is on........
    Dec 25, 2008 | Garden
    Craftsman 25cc Gas Line Trimmer Logo
    113 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
