Question about Refrigerators
The water dispenser constantly drips water. Is there a solenoid that is bad
    Scholar:
  • 103 Answers
Yes, pull refrig out from wall, remove cover on rear portion bottom of frig, follow water inlet line to where water valve is located. Be sure to turn refrig and water off before working on unit. Replace water valve, available at most appliance parts stores
Posted on Oct 01, 2009
Why is the water dispenser constantly dripping?
If the water is coming from the water dispenser itself then most likely you have a water valve that bis going bad and it will only get worse.
Jul 13, 2015 | GE Refrigerators
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
My Kenmore side by side fridge #596.55669500 is leaking through the water outlet in the door. Not constantly but often enough to be a problem. What could cause this and is it something I can repair myself?
If its dripping water mostly after using Changing the water solenoid in the back will fix the problem, Thats the blue valve on the back that is connected to the water supply line.
If its turning on intermittently and dispensing water you may have to replace the control board for the dispenser.
Its either hard water causing the fill valve(Solenoid) to not close all the way or an electrical current opening the valve .
May 22, 2011 | Kenmore Refrigerators
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Nov 04, 2009 | Kenmore Refrigerators
Water dripping from the water service
There are 2 possibilties. the most commom is if you have just replaced the filter trapped air will cause a  drip like youve described run about 1 gallon thru the dispenser to purge all air.
the next possiblity is a bad solenoid valve this is located behind the refrig in the compressor compartment. there are 2 sets of valves i reccomned replacing both sets at the smae time. these are model specific and can be ordered thru maytag or you can find them at a number of places online thx peyton...
Jan 31, 2009 | Maytag MSD2756GES Side by Side...
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
