Question about Garden
Ryobi Watergun 5000 extra pressure cleaner. On/off switvh and pressure gauge not working, although machine still works. Can't find a reapir agent on Gold Coast
4 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: Need brushes for ryobi circular saw model w-840c
You will probably have to order them through the Ryobi website. I do not think there are any service centers in Australia. I could be wrong, but there are none listed on the Ryobi Website. Heres a link for the parts website: http://www.ryobitools.com/support/parts_batteries
Posted on Sep 18, 2009
rockmeister
  • 2047 Answers
SOURCE: Brakes coast 2-3 secs. before grabbing on to
Bicycle brakes just like car brakes suffer from wear and tear. The brakes takes 2 - 3 secs before grabbing on because of 2 things. The first being that the brake pads have become flatter than they should be therefore need replacement.
Or secondly because the cables which are connected from the brake handles to the tires are a bit loose on one side or both sides. When this occurs the pressure needed for them to function properly becomes more than usual. Get this adjusted and the bicycle brake should function well without delay.
Hope this solution has been helpful?
Posted on Sep 26, 2010
  • 259 Answers
SOURCE: i HAVE BURST THE HI
Some parts stores can make the hose up. Show them the old fitting that connect to the pressure washer.
Posted on Mar 22, 2011
Motor will not idle down
Your carburetor is the problem. Either have it serviced or get a new carburetor. You can service it yourself, you will need carburetor cleaner, very thin gauged wire, air compressor if you have one to blow out the ports etc..
Also you can check out you tube for videos on how to clean a 4 cycle carburetor
Nov 05, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
How do I replace the petrol primer bubble
simple !! just obtain a Ryobi fuel system repair kit (any Ryobi dealer ) , this includes a new primer button , unscrew two Phillips screws holding clamp ring down around bubble (save them) remove damaged bubble (all of it, sometimes leaves behind bits of it) install new bubble and verify it's down in groove , reinstall clamp ring and screws , fill fuel tank and prime button (pushing it )
Apr 20, 2015 | Ryobi Garden
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
Our Ryobi 3100 2.5 gpm worked one time and has no pressure. I am livid. How do you fix it? what good is a pressure washer without pressure?
These have very small openings. Try cleaning end with fine wire supplied with your unit. Any slight corrosion will cause your current problem.
Sep 10, 2014 | Garden
My hayward sand filter pool guage is registering 0 although the pool seems to be running fine. Guage was just replaced last summer.
  • Those spring type gauges break constantly, most likely broken again, they cost a couple bucks extra but liquid filled are much more durable, just don't forget to remove if you live where it freezes.
May 24, 2014 | Hayward SAND FILTER, PRO SERIES
Use ryobi ht20vsk
Try Ryobi on line for the part or a Ryobi service agent in your area. From experience it is generally cheaper just to get a new machine as the motor will be 2/3 the price of a new machine if you can get spares for it
Jun 20, 2013 | Drills
I HAVE BURST THE HI PRESSURE HOSE ON MY RYOBI CLEANER.WHERE IS YOUR CLOSEST AGENT IN PIETERMARITZBURG? tHANKS BOB HATTING. 0826776011
Mar 22, 2011 | Ryobi Garden
KITCHENAID ESPRESSO 5KES100 steam pressure gauge not working
I had a similar problem. I took the guages out and found the hands were loose on the dials. I fixed them on at gthe low point when the machine was cold and they worked well after that point.
Aug 10, 2009 | KitchenAid Artisan
Stopped working suddenly
I don't get any hits on a search of Ryobi's parts site, but here's a link to an after market tool parts supplier that has a schematic that shows an exploded parts view and parts list.
I hope you find this will help you to solve your problem....Good luck!
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/ryobi/TS260
Mar 13, 2009 | Ryobi Circular Saw W/Dual Laser
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
