Question about General Electric DCVH680EJWW Dryer
I have a thunk noise as the dryer turns. One thunk for each rotation.
    Top Expert:
  • General Master
  • 78,936 Answers
Worn out drum bearings, replace them
Posted on Sep 30, 2009
My kenmore 400 electric dryer was working fine. i bought about a month ago. Up until last night. when it would turn it make a short grinding noise then a big THUNK. And i noticed the room was hotter than...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 23, 2011 | Kenmore 400 6942 Dryer
Drum makes thunking noise even when level
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 02, 2010 | Dryers
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
My maytag dryer model lde5914acm makes a 'ker-thunk' noise as the drum rotates. It makes the noise approximately every rotation of the drum. It has been getting progressively worse over the last 10 loads....
Dave,
First off I would suggest a visual inspection of the inside of the drum. Also try to observe it while it is running to see if the drum is off balance. That can happen if a large or awkward load is put in the dryer. If that doesn't yield any results then it may be time to check things out inside the machine. I would strongly recommend disconnecting power from the unit, especially if you are unsure of what you are doing. It just isn't worth the risk. Look for anything that seems wrong or out of place. Aside from that, I can't be of too much help without being there.
Dec 16, 2009 | Maytag Dryers
Makes a thunking noise with every rotation. sounds like a gear is messed up somehow. The beater hesitates as it goes through its rotation.
It probably is .. The most common cause is something got stuck in the beaters and some gear teeth got damaged.. They are very easy to replace but can be a little messy because of the grease on the gears. If you tell me your make and model I will tell you what parts you probably need
Oct 02, 2009 | Food Mixers
Thunk is steering wheel on my 2003 GMC sierra
CHECK THE TENSION OF THE POWER STEERING BELT
Jun 30, 2009 | 2001 GMC Sierra Crew Cab
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
97 dodge intrepid. motor is thunking when its running and in gear
Sounds like you already know what is wrong with it. It most likely needs a motor, or a rebuild.
May 28, 2009 | 1997 Dodge Intrepid
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
General Electric DCVH680EJWW Dryer Logo
211 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal De
Are you a General Dryer Expert? Answer questions, earn points and help others
