Question about Belle Foret Bathroom Sink Faucet - Single Post with Pop-Up Drain -
Faucet has low water pressure even though water pressure in line is good.
  • 129 Answers
Remove areator from faucet spout to make sure it is clean.
Posted on Oct 01, 2009
We just installed a moen shower faucet. Water pressure is almost nil. It's a brand new house so debris and other things should not be a factor. When the faucet is removed the water pressure is back...
There's a clog in the shut off, line to faucet, or in the faucet cartridge ... hook it up to a supply tube on another faucet, it connect to a garden hose to check if faucet is problem.
Water pressure problems on following link:
http://waterheatertimer.org/Low-water-pressure.html
Nov 08, 2017 | Moen 3175 Legend One Handle Shower Faucet...
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
We just installed a Moen Banbury songle handle faucet, and we have very little water pressue. The pressure in the rest of the house is fine, and we cleaned out the aireator filter. Any ideas?
Hi jaryan--
Sometimes when you valve off a water supply, particles of rust or mineral deposits break free and travel along down the pipe when the water comes back on, only to stop when they reach a small opening. In this case, it could be the faucet's supply line.
You already cleaned the aerator, which would have been my first suggestion. The next step is to visually inspect the supply lines for the faucet. Are any of them kinked or twisted? If they look good, the next step is to valve off the water at the shutoff valves closest to the faucet-- they should be on the plumbing under the sink.
Next, disconnect the supply lines to the faucet at the point closest to the faucet. Using a bucket, aim each supply line, one at a time, into the bucket and slowly valve on the water. How is the water pressure? Do any rust particles come out? Flush each line until the water runs clean and strong. Before you reattach the supply lines, use a flashlight to check the hardpiping on the faucet itself and visually check for any obstructions. Remove any suspected blockages manually.
Reconnect the supply lines to your faucet and check its pressure again. If the faucet's pressure is still low, you may have a clog in the faucet's interior mechanism.
--Hope this helps
Oct 05, 2010 | Moen 7835 Camerist Single-Handle Kitchen...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low pressure on hot water setting.
You almost had the problem solved. After you back flush the faucet you need to disconnect the line just before the faucet and then run the water into a bucket or down the drain until the line is flushed out. Depending on the size and amount of debris in the line you may have to flush the line further back until you get all the junk out.
The white crystal like substance is scale, a build up of minerals from your water. It might be worth your while to check into a water softener. Most water softener companies will do free water testing to help you determine if you need one. Beware of the high pressure sales gimics though.
May 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Plumber thought faucet was bad; no water came out of moen
Water came out because valve wasn't center. that is the reason they said both lines needed to work properly. It sound like a pressure differential mechanism.
Sep 24, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
Belle Foret Bathroom Sink Faucet - Single Post with Pop-Up Drain - Logo
176 people viewed this question
Top Belle Foret Plumbing Experts
Paul Carew
Tom Chichester
Are you a Belle Foret Plumbing Expert? Answer questions, earn points and help others
