Question about GE PSC25MSS Stainless Steel Side by Side Refrigerator
We have the same problem
Freezer seems to drip water and makes icicles. The door h as not been left open - bought with 5-year old home.
  • Johnny
    Johnny May 11, 2010
    bad door gasket?
  • 37 Answers
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
Posted on Jan 16, 2008
deby69
  • 16 Answers
SOURCE: water leaking from bottom of freezer compartment
the condensation drain line might be clogged.
Posted on Jan 02, 2009
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
NorseXNW
  • 8 Answers
SOURCE: freezer is not keeping cold and forming icicles along wall
It may just be a defrost timer. Search online for information. There is plenty to be had. Check with the website of GE for a parts breakdown or your manual if you still have it for the location of the defrost timer. You can turn it manually so it goes into defrost. Does the unit seem to be running all the time and never shuts off? If so that timer could be stuck in the cool mode and the evaporator is freezing up solid so air wont flow over it to properly cool. I've had two refrigerators I've had to repair that had defrost timer problems. One stuck in the defrost cycle and wouldn't turn on to cool, the other did what you are describing. It stuck in the cool cycle and wouldn't defrost you may need to manually bypass the cooling cycle several times to allow it to completely defrost. Usually it cycles in cool from 6,8 or ten hours and only stays in defrost for over twenty minutes. That should defrost it and allow it to start cooling again. If you notice that frost has disappeared inside on the wall replace the timer.
Posted on May 23, 2009
bunnydawg
  • 5158 Answers
SOURCE: ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
My icemaker 106-626636 is making ice but it is also making icicles and dripping in the bucket to where i have chunks of ice melted together. the icicle is where the black part of the icemaker meets the...
The problem is not the icemaker. It is the solenoid water fill valve in the back of the unit. You make have to use a hair dryer to defrost the water fill tube just behind the icemaker AFTER you replace the water valve. I just worked on my own and have have done in home appliance repair for over 30 years. If it is making icicles the diaphram in the water valve is shot. It is not a difficult or expensive part IF you order it on the net. Walk in replacement part prices have nearly a 100% mark up.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Refrigerators
Hi, My refrigerator has been working perfectly for ten years. A couple of nights ago I noticed that it had wasn't freezing the ice and water dripping down inside the freezer part at the internal of the...
peter if your unit doesent seem to be cooling and the commpressor sounds like its running sounds wierd but make sure the fan cooling the evaporator coils is running if there is a lot of dust also clean the coils just a thought
Apr 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
3 year old left freezer door open for 15 minutes now freezer and fridge don't get cold
Unit more than likely iced over. Unplug the unit and place a fan blowing into the freezer section for about 2 hours. You must remove the contents of the freezer section when doing this. This will make a dripping water mess so be ready with a mop and rags to tend to the drips as needed. When the drips cease you are done with your manual defrosting drill. Plug your uint back in and return it to normal service. If after 2 - 3 days the problem repeats then your unit is not defrosting and will require further service.
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
GE PSC25MSS Stainless Steel Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
