How to put recoil spring and pull rope in echo 2400 brush cutter
The recoil housing is held on by four screws around the housing on the corners, the pulley is held to the housing by one screw, all tension needs to relieved from the spring before removing the pulley. you can either cut the rope if you are replacing it, or you can pull some of the rope out, lining up the notch in the pulley with the outlet hole, catch the pulley and hold it from rewinding, and using the slack in the rope pull a section back in and up through the notch, the pulley can now unwind its tension without winding up the rope. Now remove the pulley, it should leave the spring in the housing. If the spring is very rusty it should be replaced, if you've sprung the spring out and have a mess, be prepared for a little fight, you can try hooking the outside of the spring in its tab in the housing and while forcibly holding that in place begin coiling the spring back in place, or try gathering the spring into a large coil and holding the coil with a pair of pliers begin shrinking the coil's diameter by winding it up from the center, last resort and the one I'd recommend if you're looking at a rusty spring, get a new one from an Echo dealer, it comes pre-wound and a nifty retaining clip, it simply slides into place in the housing, and as it goes into place the ring will pop loose. Now for the rope. Install the rope by putting the new piece in the spool and tying it off, thread the other end through the housing from the inside out, and put it into the handle and tie it off on that end, now place the spool into the housing being sure to engage the spring lightly, now install the screw so the spool doesn't come out, pull the slack rope up through the notch in the pulley and begin winding the pulley in the direction it turns when the rope is normally extended, after about 4 turns drop the rope out of the notch and let the pulley wind up the rope, if you have slack repeat a couple turns until there is no slack
