Question about Gateway GT5220 PC Desktop
No video, shows orange light on front which gateway says video
Have a gateway gt5220 pc. no video, it did updates then wouldnt come back on..checked all hardware in another case similar board, tested everything, cpu, p/s. & all drives...pulled battery for a day, still wont give me video.. gateway is not helpful @ all, there book doesnt give em' my answer ...cant find a bios update,flash or squat... can anyone help. thank you. jr
  • 1 more comment
  • dennyjr47 Oct 01, 2009
    onboard, tryd pci express & pci, neither fixed it....thanks tho
    i lost my video connection, checked all hardware & drives,including ram, everythings in good working order. computer comes on 2 an orange light,which means video fault,tried a pci express, pci & onboard,still no video..but after reading all the problems with this mobo combo,i think its the bios needing updated/flashed, or the mobo needs destroyed...
  • vladkov89 May 11, 2010
    it the graphics card problem. you need to get a new one for your computer
  • 71 Answers
It sounds like your hardware is not compatable with the update. if you can restart the computer and press f12 to boot to safe mode you should be able to open the device manager from Run: by typing devmgmt.msc, find the video adapter under 'display adapters', double click your adapter to bring up the properties window, click the 'driver' tab and click roll back driver
hope this helps. please rate me and thanks for choosing enterprise computing solutions...
Posted on Oct 01, 2009
Testimonial: "helpful, but still no video...thanks tho, "
Gateway computer Where is my video card located & how do I remove it? I have a gateway GT5220
the graphics on this specific machine are integrated onto the motherboard, it's not removable, so you'll have to live with it unless you get a more powerful addon graphcs card and put that into the orange slot on the motherboard (the specific slot type is PCI-e 1st generation (GEN1) 8x) and upgrade the graphics to a more powerful nVidia or ATI(AMD) one!
Aug 07, 2013 | Gateway Computers & Internet
Can I install USB3 in a Gateway Model GT5220
Put one of these in any available (Open) PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5601679&CatId=511
http://support.gateway.com/us/en/s/PC/R/1009151/1009151nv.shtml
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
(The two long White slots at the bottom right, are PCI slots,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rmvr16.shtml
,the long Orange slot is a PCI-Express x16 slot. This = No
If you would like guidance in installing post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Gateway GT5220 PC Desktop
Is my ethernet card bad?
Yes. You might also have a bad cable, or a bad modem or router.
Apr 20, 2010 | Gateway GT5220 PC Desktop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
Upgrading pc question Gateway GT5220
you can go to
http://www.pricewatch.com/video_cards/pci_512mb-0.htm
to check out video cards as welll as check out the ram you can go up to 4 gig.
Mark
May 05, 2009 | Gateway GT5220 PC Desktop
Missing color red only blue/green/yellow appear on monitor
try to swap another minitor. If same thing happens. Try to update your video card driver.
Mar 19, 2009 | Gateway GT5220 PC Desktop
Pb not seeing my new video card
The 9600 video card, I am fairly sure, has a connection on the card itself for power. Have you maybe fogotten to connect the power supply to the video card? If not , try reseating the video card.  A third possibality.. Some MB, if they have on board video, require you to turn off the "on board video" in order for it to use (see) the New PCI video card. Hope this helps.
Dec 06, 2008 | Gateway GT5220 PC Desktop
Constantly reboots itself
The Gateway GT5220 has an AMD Athlon 64 processor. It has been documented that Windows XP SP3 doesn't play well with some AMD CPUs. I'm pretty sure this is one of them. I would suggest attempting a system recovery using a restore point on a date BEFORE you installed SP3. If that doesn't work, you might consider recovery using the original Gateway Restore CD. It will likely wipe the system, but that might be the only choice.
I would NOT start with the total reload option. We have a couple others before you get there, so try the restore point and then let me know the results. We'll go from there...
Regards,
Char1ieJ
Nov 04, 2008 | Gateway GT5220 PC Desktop
Want to disable power management flashing blue light on GT5220 PC
I don't think that's practically possible until you have to do it through the hardware inside..
However you may do some manipulation to the power plan of the computer system..
Aug 21, 2008 | Gateway GT5220 PC Desktop
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Gateway GT5220 PC Desktop Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
