Question about SanDisk Sansa e260 MP3 Player
Completely Wacky 'Sansa e260'
I've had my e260 for 3 or 4 years, its worked fine up until about a year ago, now it seems almost useless.
It turns on just fine, and still plays my music, but when I turn the wheel to the right to go down my song list or turn up the volume, it goes up the song list and turns down the volume.
It randomly turns the volume on itself up all the way, it commonly freezes, sometimes for 2 or 3 days at a time.
I cant add or delete songs at all when its connected to my computer, because it just restarts itself. It'll also stop playing right in the middle of a song but start back up a minute or so after it works itself out.
I'd like to know if/how I can fix my mp3 without completely resetting it[deleting all my music] but im thinking its time for a new one.
Any tips or advice would be greatly appreciated. :]
--Shay
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. That will be the only way
Posted on Oct 01, 2009
When I attach my player to my laptop and try to get updates the site says to delete some music. I don't know how to do that. Also everytime I turn the unit on it prints accross the screen that it's updating data. I have a 4.0 GB unit with 2.0 additional in the macrThanks
Posted on Oct 15, 2009
I hame had a Sansa 4gig since the beginning of the
restore drivers by using SYSTEM RESTORE to a date when they worked. Enter the product model # and find site that provides drivers download and reinstall um.
window path
Start,Acessories,System Tools, System Resore
Nov 22, 2009 | SanDisk Sansa e260 MP3 Player
Choppy audio on Sansa e260.
To me it seems like the head phone jack is loose, it might need to be re soldered and then things would be back to normal. HOpe this works.
Wayne
Jun 26, 2009 | SanDisk Sansa e260 MP3 Player
My computer wont recognize my USB
Try the following steps:
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
Jun 04, 2009 | SanDisk Sansa e260 MP3 Player
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Sansa e260 volume will not work?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Mar 10, 2009 | SanDisk Sansa e200 MP3 Player
Stuck in language mode
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Display problems sansa e260
Not me. But i would call a repairman
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
WON'T TURN ON
I just got an e260 today and had the same problem. When I originally turned it on the Hold was in the 'locked' position. From there on out the screen has been black. When it was plugged in nothing happened either. The Solution? Hold the power button for about 20 or so seconds. The manual doesn't tell you about it, but that's how you completely shut the sansa down altogether. Yes, the manual says it's also a reset button but it isn't mentioned how you actually use it. Once you hold that button down long enough it should completely shut down and restart.
Dec 03, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
226 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
