Question about Kenmore Dryers
I have front loader dryer and the door is popping
I have front loader dryer and the door is popping open, won't stay shut
  • 304 Answers
Buy door latch kit from parts supplier. Comes with male and female parts of latch. Replace female part first and see if problem correct. Replace male if necessary. Don't worry if parts break off and fall inside while removing old pieces.
Kit is very inexpensive. If after replacing both parts your door still pops open check to make sure door is not sprung. To do this place a known straight edge across center of door from left to right and be sure there are no gaps between door panel and straight edge. If no gaps, replace hinges. They are likely bent.
Posted on Oct 01, 2009
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryer door won't stay closed
hi,
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Jun 17, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Mar 12, 2008 | Dryers
Dryers Logo
280 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
