Question about LG WM-2077C Front Load Washer
Water leaking out of back air vent
I noticed a water stain on the floor. I determined its coming out of the air vent on the back. This is a rubber stretchable hose that goes from the top of the drum to the back. Guide says it an air vent. Its not much water but enough to notice, maybe a cup or two over 4 or 5 loads. but enough to see water on the floor. What can I do? or why is it seaping out?
JohnR
rockey_2@hotmail.com
  • 2 more comments
  • unella Sep 27, 2008
    I have the same problem. It seems to only happen when I wash our comforter.
  • Anonymous Mar 21, 2014
    Water leaking from air vent at rear
  • Anonymous Mar 23, 2014
    Water is leaking out of the air vent below the water lines.
    water coming out the air vent on back of washer
    Champion:
  • 249 Answers
Check your filter,and see .!!!water may not be pumping out fast enough!!
Posted on Dec 20, 2007
1996 Jetta leaks water on the right front floor panel when it rains. I can't see any leaks around the windows or windshield, seems to be coming from under the dashboard and gets on top of the rubber floor...
If your in cabin air filter is accessed from the outer dash area, under your windshield wipers, your seal may be good eon the over. Check to see if your cabin air filter is wet
Feb 01, 2018 | Volkswagen Jetta Cars & Trucks
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
Water drip inside car when its rains on a crown victoria ford ,on the floor board . had my ac fix two years ago cause hot air was blowing in cause the ac air was not coming in to good . something about...
Most likely the windshield is starting to leak -
Second choice is - there is a drain hose - it may be clocked up - please pull up the floor man - and look for a rubber hose that goes down through the floor board.
If that hose is clogged it will only be wet when you run the AC and you will notice not much water coming from under the car from the drain hose which exits under where the passengers feet are.
Best of it - hope this helps
Mar 20, 2010 | 1992 Ford Crown Victoria
I have water leaking on the right rear floor passenger side
Sounds to me like your issue is with condensation from your air conditioner. The condensation isn't properly draining, probably from a damaged or clogged drain hose.
Jun 16, 2009 | 1990 Toyota Camry
1994 Jeep Grand Cherokee Water leaks
It is most likely leaking from the windshield and running down to the floor. Good luck and dont forget to rate
Mar 23, 2009 | 1994 Jeep Grand Cherokee
Water leaking into KH laser Hatchback
It could be coming in through the rear door as the rubber might not be sealing properly the easiest way to find the leak is to remove your seats and carpet sit inside get someone to squirt the car round the doors and windscreen air vents.
Feb 25, 2009 | 2006 Ford Laser
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Water under driver side floor
It may be due to the air conditioning hose being blocked. Therefore the water must be backing up into the vehicle, under the carpets and into the back seats instead of flowing out
Sep 29, 2008 | 1999 Lexus Gs 300
LG WM-2077 Water leaks out of the Air Vent on the back
Be sure you are using HE detergent and only about 1 Tablespoon for a load. You are ending up with too many bubbles in the machine and when it goes to spin the bubbles come out the air vent. There is a valve that closes during spin but bubbles are not strong enough to lift the valve it has to be water hitting it before it closes.
Dec 20, 2007 | LG WM-2077C Front Load Washer
LG WM-2077C Front Load Washer Logo
621 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
