Question about Bose QuietComfort 2 Consumer Headphones
The pads are teaard and Yellow Sponge of the pads came out,
You can get replacement cushions on ebay for about
Posted on Aug 30, 2010
    Scholar:
  • 92 Answers
Based on what you are saying, those are the signs of old age, unless the dog got them..
Short term solution is to put the foam back in as best u can, and either glue or duct tape the covering back in place.
If you use the duct tape, be sure to not to cover the area where the sound comes from when you repair them.
The duct tape will not affect the comfort factor if applied smoothly and wrinkle free,
Long term solution is to replace the ones you have.
Check around for pricing.
If your sound equipment is fairly new, wireless headphones are an option.
Happy listening.
Posted on Oct 02, 2009
Repair scratches on a stainless steel refrigerator
YOU WILL NEED A POWER POLISHER WITH A BUFFING PAD AND SOME YELLOW ROUGE AND WHITE ROUGE, (CAN BE PURCHASED AT HOME DEPOT TOOL DEPARTMENT). APPLY BUFFING PAD TO POLISHER AND TURN ON, SET TO LOWEST SETTING, APPLY YELLOW ROUGE TO PAD AS IT SPINS, ( START AT CENTER OF PAD AND MOVE OUTWARDS), DO THIS TWICE THEN BEGIN POLISHING STAINLESS,APPLY SLIGHT PRESSURE BUT ALLOW POLISHER TO DO WORK, REPEAT AS NEEDED, APPLY WHITE ROUGE TO BRING OUT SHINE.
Sep 20, 2011 | LG LRFD25850 French Door Refrigerator
Cannon Mp780 not printing yellow at all. Ink tanks are full.
CANON MP780 DOES NOT PRINT
This is what works for me. Try at your own risk. You may need to clean both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The one separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
#8
Jan 01, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Ink absorber is full
Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small.You can remove the pads and the holder with a gentle pull.Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dryed and placed again. Be careful and patient. On the MP240 this requires the dismantling of most of the printer. Take a photograph (even with your cell phone) so you can trace back your steps. On the MP240 the drive motor on the side (Just behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.Carefully replace the holder and the pads. Close printer.Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power.Release the power button.Press the power button again.
Nov 30, 2010 | Canon PIXMA MP240 All-In-One InkJet...
HOW DO I REPLACE OR CLEAN THE INK ABSORBER FOR THE IP1800?
Hello,to replace it you must take it to cannon service,to clean it you can try Opening your printer,but first wear glove to protect your hands,locate the waste ink pads on the instide of your printer(small partson the right).You can remove the pads and the holder with gentle pull,using a tissue or a sponge soap as much ink you can and clean the area around the waste ink.It should be one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dryed and placed again. Be careful and patient.Take a photograph or note somewhere, so you can trace back your steps.The drive motor on the side (behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage.
Carefully replace the holder and the pads and close printer.Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power,release the power button,press the power button again.Your done
Good luck
Jan 22, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Epson C86 print head/cartridge head won't move.
Hi Beverley
There is some confusion here. You say "ink sponge needs replacing" in an Epson C86 (although you have your query posted under HP Officejet 5610!) - I presume you mean the waste ink pads. If so, you need to dismantle the printer - the pads are not under the print head but deep inside the case. I can provide all the information you need to complete this task if you really want to do it yourself. Please post a new comment requesting this assistance if you do.
Apr 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Mar 26, 2009 | Epson Stylus C66 Inkjet Printer
Do the Solitab tablets have the small yellow sponge included with them
Hi
Yes the sponge is in the tablet and when the tablet disolves the sponge soaks up the oils, they say.
Mar 09, 2009 | Solis Master Top 517
Cleaning up the mess of black ink leaking
You shouldn't need to clean it. Just squeeze it like you would a sponge using something like a paper towel. This is a messy endeavor, be careful.
May 22, 2008 | HP Officejet 7210 All-In-One InkJet...
Bose QuietComfort 2 Consumer Headphones Logo
203 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
