Question about Garden
I have a murray riding lawn mower and the model number says its a 40702X92C. I can't find anything on this mower at all Is this even the correct serial #
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
freetek
  • 5568 Answers
SOURCE: how do i route the drive belts on my murray riding
You can download a manual for your Murray here:
Murray manual
This is in .pdf format so you must have Adobe Reader or equivalent available.
FYI: Murray remnants have been bought by Briggs & Stratton so engine parts are no problem, everything else is sketchy.
Posted on Aug 25, 2009
mowerman1857
  • 389 Answers
SOURCE: how to install drive belt murray lawn mower
You can go to www.murray.com , enter your model number and download an owners manual which will have the instructions and diagram on how to do it
Posted on Sep 24, 2009
  • 33 Answers
SOURCE: Murray select riding mower model 309000x8NA won't start?
check ground wire and posts for continuity between battery and starter, if you don't have a multimeter, remove, clean and replace all ground connectins. If that isn't it and you are sure that your battery is good and you've got good juice to the starter than the starter needs op-checked, remove it from the engine and engage it, if gear shifts out and spins rapidly you may have engine problem. Hope this helps...
Posted on Mar 29, 2010
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
I need a deck belt for my Murray riding lawn mower model number is 13an772s058
If you still have the old belt, even if it is broken. Taje it to your local lawn and garden center that sells parts and service on riding mowers. Have them measure the belt length and width. If the belt is missing, have them look up belt for the model number of the mower you have.
Oct 13, 2015 | Murray Garden
40702x92c murray
take it to a small engine shop and match it up... somewhere between 10 and 50 bucks...
Sep 03, 2014 | Garden
I am looking for an owners manual for 425000X8 Murray riding lawn mower
andrew?so you need a manual for 425000x8A this is a 2003 model I found this manual for free at murray.lawnmowerguides.com/murray-lawn-mower-manual.html when you see your model number on your mower it look like this 425000x8 the A tell you the year it was made the 2004 model is 425000x8B BOTH MOWERS LOOKS THE SAME AND THEY HAVE THE SAME FRONT GRILLE.
Sep 17, 2011 | Briggs & Stratton Garden
Intall a deck belt on a 42" murray riding lawn mower
http://www.ereplacementparts.com/ type in your model number all the diags you need, yours Henry
Sep 04, 2010 | Murray 46 Primary Lawn Mower Blade Belt...
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
How to install drive belt murray lawn mower
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
