Question about RTO PasLode 900420 Impulse Framing Nailer
Trigger problem - RTO PasLode 900420 Impulse Framing Nailer
  • ashley1232 Oct 11, 2009
    it is an im350 usa model with a black handle.when nib gets pushed down the fan doesent turn on and when you relece pressure of nib and pull trigger the fan kicks in
  • David Ford
    David Ford May 11, 2010
    could you be more specific on the problem and give me the exact model number and I will try and help
  • 108 Answers
Trigger solution
Posted on Oct 11, 2009
How do I replace the trigger spring on E9131
Trigger Spring replacement procedure - DualShock 4 - iFixit
https://www.ifixit.com/Answers/View/.../Trigger+Spring+replacement+procedure
Sep 4, 2015 - How do I replace the trigger springs ? - DualShock 4. SOLVED: How can I remove the magnetic triggers ...
27 Nov 2016
How to replace trigger spring? - Xbox One Wireless ...
1 answer
5 Aug 2016
More results from www.ifixit.com
Missing: e9131
DualShock 3 Trigger Buttons Replacement - iFixit
https://www.ifixit.com/Guide/DualShock+3+Trigger+Buttons+Replacement/3253 DualShock 3 Trigger Buttons Replacement: Replace a broken trigger button. Missing: e9131
New ps4 controller, where does trigger Spring go? - PlayStation Forums
https://community.playstation.com/content/pdc/.../new_ps4_controller-bc71.html ... Spring go? 10 replies. I've took apart controllers before but this must be a different model. The Spring doesn't sit on the small ledge inside the trigger. It has nowhere that I can see it can fit inside?? It's a glacier white controller so it's a newer model. Please someone help? BRIT-KO (Support MVP). 05/28/2016 - 11:25am.Missing:
replace the trigger spring on E9131 Google Search
Mar 07, 2018 | Garden
Will not fire a nail when triggered.air passes through and out of trigger. seals checked ok. driver checked ok
pound out the trigger rocker switch and see if its that. press the trigger valve button without the trigger in place. could be your trip is not engaging the trigger far enough to make sufficient pressure to push the trigger down .
Nov 09, 2015 | Porter Cable DA250C 15Ga 212" Angle Finish...
My husky framing nailer leaks air around trigger
Leak around trigger could be trigger valve internal orings or orings on the outside of the trigger valve making contact against the body of the gun. Spray soapy water to determine where the air is leaking from. If air is leaking around the outside of the valve, most likely the orings were cut upon installation of the valve. If leaking from internal valve, most likely worn or broken oring; easy to fix if you have a source for orings.
To remove the trigger valve for service or inspection (take close-up photo of trigger area for reference ):
disconnect airline, remove nails, remove trigger retainer pin, remove trigger, remove roll pin /s holding trigger valve in place (use 3mm punch to remove retainer roll pins which are located in the body of the gun just above the trigger valve). With retainer pin/s removed and with gloved hand (under trigger valve), apply air pressure to gun to blow out the trigger valve (use lower pressure to push out trigger valve because it could come out with force.). With trigger valve in hand notice that there are two slots or groove cut neer top of the valve where the retainer pins rest, you will need to reinstall valve into body with slots aligned to retainer pins. Remove retainer pins holding trigger together to pull out internal valve. Good luck and post again if your have other question about the trigger valve.
Nov 15, 2012 | Air Tools & Compressors
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Central pneumatic roofing nailer,where is the nailing ajustments?i should be able to hold the trigger and touch the nose to fire repeatedly but it wont let me.dont see a ajustment?
Not all nailers have the ability to bump-fire. It depends on the type of trigger and the firing valve that the trigger contacts. Remove gun from air supply and remove the nails (for safety). Take a close look at the trigger itself looking for a bump fire setting. It will have a rotary dial to select single or repeat fire. If no setting, look at how the safety foot contacts the trigger's inner trip lever (the trip lever inside the trigger is what actually contacts the firing valve pin). With trigger pressed in, push the safety foot in and notice if the safety contacts the inner trigger lever. On bump fire trigger, the safety foot mech. will push up on the inner lever each time that you press in safety (and you will see that the inner lever will depress the firing pin). On single fire trigger, with trigger pressed, when you push on safety foot, the mech. will not contact inner trigger lever because the lever is too short to allow safety to make contact with it. On single fire triggers, the inner lever can make contact with safety only when trigger is in the resting position. With trigger released, depress safety and notice that safety contacts inner trigger liver and will remain in contact untill you press the trigger at which time the inner lever will depress the firing pin then fall away from safety. If you are a tinker-er, you can make adjustment to inner lever so that it will make constant contact (the rotary dial on triggers that are made to give you a choice of bump or single actually make the inner lever longer or shorter ). If you make any adjustments, make various and numerous tests with-out nails to make sure that it will not fire accidently.
Mar 21, 2011 | Air Tools & Compressors
The spring in my trigger flew out. how do i put it back
The n60fn uses two triggers, rapid fire trigger (black metal) is pictued with your post and does not need a spring. Just replace the 3 mm roll pin that holds trigger to the body of the gun and you should be good to go. The other trigger is the white plastic sequential. The sequential trigger uses a fine spring between the trigger and centered on the tva6 trigger valve. Parts and breakdown at www.toolpartsdirect.com. Good luck
Aug 23, 2010 | Stanley Bostitch Air Nailer Trigger N60...
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
TRIGGER IN SQL
A trigger is a special kind of stored procedure that automatically executes when an event occurs in the database server. A trigger is really an event handler. SQL Server allows users to create triggers (event handlers) for 3 types of events:
  • DML Event - Occurs when a DML (Data Manipulation Language) statement: INSERT, UPDATE or DELETE, is executed.
  • DDL Event - Occurs when a DDL (Data Definition Language) statement: CREATE, ALTER, or DROP, is executed.
  • Logon Event - Occurs when a user logins to the Server.
There are 3 different types of triggers (event handlers) based on the types of events they are triggered by:
  • DML Trigger - Executes in response to a DML event.
  • DDL Trigger - Executes in response to a DDL event.
  • Logon Trigger - Executes in response to a logon event.
Jul 03, 2008 | Microsoft SQL Server 2000 Standard Edition...
RTO PasLode 900420 Impulse Framing Nailer  Logo
106 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
