Question about Dell 924 All-in-One InkJet Printer
I bought refilled catridges for my printer and it printed the test page fine. But will not print any documents from my files.All my connections are good and it even printed test pages from my computer what could be the problem?
    Sniper:
  • 51 Answers
Most of these issue are caused by either corrupt printer driver or busy print spooler.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day :)
Posted on Oct 01, 2009
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
I was printing on my printer with no problem when in the window of the printer it shows cartridge error,error 1203.I checked the cartridges and they look fine.I took them out and put them back in I...
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it works for you. Good luck......
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
Error 1203 printer not working
Here is what I found about the 1203 error in the dell community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Jun 16, 2009 | Dell 946 All-In-One InkJet Printer
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
HP PSC 1200 color problems with website prints
It strabge... Anyway u just clean your print heads and nozzles... it shuld make it fine... or just replace ur catridge...
Sep 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon pc-d320 printer catridge
The issue you have described regarding your printer is mainly due some dirt on the printer drum, As most of the issues like this get solved when you clean the Drum, However before you start troubleshooting your printer you should try few steps to check where actually the issue lies is it the Drum or the cartridge or is it with the driver software or even with the document file software program that you are trying to print form, so try these steps below to know where the issue lies here is what you need to do,
Try to scan and print a document, by using the copy option on the printer control panel directly (Check if the print is good, if so then the issue is with either the printer driver or the document software you are trying to print).
If you find that the print output is the same which means the printer again printed a complete black page try to clean the Drum of the printer with a soft dry cloth. Please make sure that you completely disconnect the printer power cord and leave the printer powered off for sometime before you remove the printer cartridge and clean the Drum.
Alternately you can also try the old cartridge if you still have it with you just to check if the print out is fine with it, with this we can isolate the issue as we will come to know that the Toner cartridge is gone bad and you can then replace it.
However if you find the copy was fine then you can try printing a test page and check if its good. (If you find that if the test page prints okay, then try printing any other document form a different program however if you find that the test page looks like the same I mean if it is completely black then you can try to uninstall the driver and reinstall it again).
Here is how you can uninstall the driver and reinstall it.
1. Click on start, point to control panel and click on control panel.
2. Click on Add/Remove icon and select the printer driver and click o remove.
3. After the un-installation wizard is complete close all the windows and disconnect the printer form the computer.
4. Insert the driver disk in the Disk drive and install the driver.
Note: Do not connect the printer to the computer until the installation wizard asks you to do so.
If the document prints fine, you will then have to check the setting of the software programe that you were trying to print form earlier or even you can try to uninstall and reinstall the program to fix the issue.
I believe that the above mentioned steps will fix the issue however, If the issue is still not fixed please keep me posted with the latest information so that I can provide you further resolution steps accordingly.
Regards
Malik Khan
Jan 26, 2008 | Canon I990 InkJet Photo Printer
Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
bye
Nov 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
241 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
