I have a busy 42 hi on my brivis heater
I have a brivis heater system and it is saying BUSY 42 HI. Which i'm sure some brivis tech would know what was wrong with it right away. It will cost over $200 to fix and I do not have the money. Was wondering if anyone has fixed this themselves or if it is even fixale????
3 Suggested Answers
  • 3247 Answers
SOURCE: My brivis climate system (auto EMS series EMS20)
Have you seen this Instructions Manual which explains some of the actions to check the system.
Have you checked that the gas supply to your premises is working well. You will have to confirm there is no air in the system which is preventing the pilot from re-igniting.
Depending on where you live in Melbourne you can find a local repair technician who can help. Try the local newspaper classifieds. For the north & west try this mob. You can also try Service Central and post the job.
Hope the unit works soon. It must be awful not to have heating in winter.
Posted on Aug 22, 2010
SOURCE: brivis central heating problem code ''busy 40 H1
Hi, i recently had the same problem with mine and found that the inside adapter was unplugged. I plugged it back in and all is working find, so if anyone has the "Busy Hi 40" message on the control box the check the adapter :)
Posted on Dec 21, 2010
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Brivis central heating problem code ''busy 40 H1
Apr 19, 2009 | Heating & Cooling
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Jun 10, 2008 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Printer is busy
Hi, cancle the earlier pending documents, which have piled up in the queue.. let me know
Dec 17, 2007 | Dell 924 All-in-One InkJet Printer
Heating & Cooling Logo
687 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
