Question about Mitsubishi VS-50609 50" Rear Projection Television
Red convergence is all messed up, won't let me adjust it up and down, but will adjust left to right.
  • Mitsubishi Master
  • 8,457 Answers
Ur convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.This website have the kit.Tv Repair World.com.
Posted on Oct 01, 2009
Hi in the convergence to adjust the color the red is above the plus sign in 3 spots and will not come down and they are not straight
does the blue convergence crosshairs move up and down left and right? Does the red move left or right. does the red move up at all. this might indicate a faullty resistor, bad ic or just bad convergence data. let me know i am here to help
Nov 04, 2010 | Toshiba 43A62 43" Rear Projection...
The blue and the red colour do not line up. converging still does not fix the problem
First shut the set off. Then press the channel up and volume up this should get you into the service menu where you can reset the convergence. if it doesnt reset then you might have a cuircit problem/ WARNING...The service menu adjustments can and will cause the set to shut down. i really dont suggest getting into this but if you do be careful not to mess around to much. the convergence is spread across three diffrent cuircit boards. Question you can ask before you attempt any adjustment is when you try manual adjustment does the crosshairs move left or right up or down. on either the red or blue at all if they do the chances are good it can be fixed without replacing any parts..... i am here to help so if you have anymore questions let me know.
Nov 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Red ghosting
You need to replace the convergence amplifiers. Mitsubishi part # 267P155010 and generic part # stk393-110. If there are 2 of them in your set, replace both.
Jun 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Picture pretty good but vertical lines (shadows) and ghosts
You're going to have to be more specific. When you are messing with the convergence settings, are all of the crosshairs straight lines? Are they crisp or fuzzy? Can you successfully move the Red and Blue crosshairs up/down/left/right? Have you opened up the TV yet? I'll help you from there once we get some details.
Jan 05, 2009 | Hitachi 46UX50B 46" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi VS-50609 50" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
