Question about Dell Dimension 3000 PC Desktop
My Dell Dimension 3000 PC won't start when I push the power button
  • Dell Master
  • 5,660 Answers
A.Bad Power On switch. (Behind the Power On button)
B.Bad power supply
C.Power supply cables have come loose inside the computer.
1.Power supply to motherboard. (20-pin connector on motherboard)
This connector has two pins in it for Soft Power On. The power supply does not connect directly to the Power On switch. The power supply connects to the motherboard, and turns on via Soft Power On.
ADVISEMENT!!
ALWAYS have the computer unplugged from power before reaching inside!
ALWAYS work on a table. DO NOT work on a bed, or directly on a carpet floor. These are high areas for Static electricity! Static electricity will silently burn out computer hardware components. You may not see it or feel it.
Touch the metal frame of the computer case, to relieve your body of static, BEFORE you reach inside.
Posted on Sep 30, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dell dimension 3000 won't turn on
No way to teat but to install another PS.
Jul 31, 2012 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 doesnt recognize cdrw drive
Drive might have gone bad possibly? Or power the PC down completely push the power button for about 1-2 seconds to discharge the PC then plug it back in and restart the computer. If this does not work and you still cannot see the device. Check the cables and make sure they have not come out or are loose. If this is not the problem then you may try downloading the driver file for it at Dell.com replace drive if necessary. John
Apr 19, 2012 | Dell Dimension 3000 PC Desktop
My dell desktop won't start. when press the front panel button, computer won't start
check the power connections, if its okay change the power supply or smps
Jul 27, 2011 | Dell Dimension 3100 PC Desktop
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 flashing yellow light
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Jun 26, 2009 | Dell Dimension 3000 PC Desktop
Wireless keyboard went dead. Have changed batteries & pushed all green buttons
I had the same problem with my keyboard and it turned out to be a manufactureing problem I just got another keyboard.
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 desk top, does not turn on ?
It's one of two problems: bad power supply, or bad motherboard. If you are electro-mech inclined, remove the power supply. Take it to your local computer repair shop, and ask for one just like that one.
Reinstall, power up should (most of the time) fix this problem. If still no power, you need a new mb. Return to the shop, ask them to replace mb. This repair should be right around $250.0 - tops. Any more than that - replace computer.
Hope this helps. Either way, if you wouldn't mind taking the time to rate my response, it would be much appreciated!
Thanx and good luck.
gurutim
Mar 22, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000
There is an L shaped lever on the back. Press and hold that down and push side panel of case back. It will lift off. When you put it back on just align the slots on the bottom edge and push forward to close it.
Feb 14, 2009 | Dell Dimension 3000 PC Desktop
Error
please unplug all external devices from the back of the system tower , unplug the power cable and push the on button on the system and count 1-20 replug the power cable and power on the system the issue wil be resolved
Oct 25, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
299 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
