Question about Sony Cyber-Shot DSC-P72 Digital Camera
Flash won't work when it's cold outside. Camera shuts off by itself.
  • 32 Answers
How cold? Most rechargeable batteries will not work properly much below 0 degrees Centigrade. If it is much colder than that, it is likely that the batteries are shorting out and the camera is not getting enough current.
Try keeping the camera warm until you use it (under clothing, in a pocket etc.)
Posted on Jan 02, 2008
The camera keeps turning on and off by itself
When your camera shuts off by itself, it has detected an error inside. Could be hardware failure, but also a software problem. So no use of switching it on again. Please when it shuts down again, wait till no memory access light is burning or flashing. Then remove the battery. The best thing before reinserting the battery is to charge it first. But if you are sure the battery is fully charged, wait a few moment before you reinsert the battery. Then when you have put in the battery switch on the camera.
When you remove the battery for a few moments, the camera will have a "cold" start. So the program that makes your camera work, start from scratch. As long as the battery is in the camera, the program in the memory does not change. That is why you should the battery.
If your camera has a hardware failure it won't be solved when you remove and reinsert the battery. If the switching on and of occurs while zooming, it could be the lens mechanism has a problem with the gear or motor. If this happens, you should visit a service centre, or buy a new camera.
Then it could be the battery is charged, but not powerful enough to do all tasks. If the camera detects the voltage is under a certain level, the camera also shuts down. If every time the flash has to charge, or the zoom or AF motor needs to work, the camera shuts down, it could be the battery is on its end of life. But for that you should look on the display. Most cameras do have a battery level indicator.
Feb 04, 2014 | FUJIFILM FinePix JX250 Digital Camera
Dmc gf1 flash won't work
The camera requires service, this is a nag screen and will not reset itself without being serviced.
Jan 17, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
Can we use a Cobra Auto 150S Compact auto/manual flash and slave unit on a Nikon 5000 SLR
As a slave, yes, though you won't get any of the features of a Nikon CLS-compatible flash unit. You would be shooting in manual flash mode. Due to its higher trigger voltage, I would NOT put the unit onto the camera itself.
May 23, 2011 | Nikon D5000 Digital Camera with 18-105mm...
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
My carrier heat pump has frosting on the outside on it's coils. I know that it's cold outside but is that normal?
Yes it is normal especially with high humidity. The moisture freezes on the coils just like on the evaporator coils in a freezer. The heat pump will defrost itself by shutting off the fan outside and reverse the flow of refrigerant to melt the ice when it build up then switch back to normal heat. That's why at times you may feel cold air coming out of the vents in the house. The outside coils are defrosting.
Dec 16, 2010 | Heating & Cooling
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Recirculation light and ac light flash when you push them
when it is cold out your car is designed to make sure it is not on recirculation mode if it was your inside windows would be all fogged up because of humitity .
Jan 30, 2009 | 2007 Chevrolet Equinox LS New Cars
FLASH WONT TURN ON
You can try cleaning the terminals in the battery compartment with a pencil eraser (a good idea in any case). Otherwise, I suspect hidden damage or fault. If not an expensive unit, replace it.
Feb 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Sony Cyber-Shot DSC-P72 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
