Question about KDS Valiant 6370iPT Notebook
Cant get the ethernet adapter to function ?doesnt identfy it on the hardware listing either
  • saltsea210 Oct 02, 2009
    Thanks but KDS doesn't even have a web site for thier notebook computers customer support, and i have found a lan driver for win 2000 pro which i reinstalled removing the win xp thinking i could get the lan hardware port to work but it isn't an .exe file so its not self installing . and well im still searching for the dos flash install instructions required to install the lan driver on the modelkds6ksumo ( valiant 6370ipt note book computer i have some times thier more work then the older ones are worth lol have a great Day Steve
    Problem Solver:
  • 6 Answers
You are maybe missing the drivers, go to a friends computer with your computer information model and make download the drivers from the companys website save them on disk and load them on your computer
Posted on Oct 01, 2009
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
Patricia,
Left-click on Start, then Right-click on My Computer.
Left-click on Properties at the bottom of the list.
Left-click on the Hardware tab.
Left-click on Device Manager.
Once Device Manager has fully loaded left-click on the + sign, next to Network adapters.
What Ethernet chipset are you using? Intel, or Conexant?
http://www.dell.com/support/drivers/us/en/19/Product/dimension-1100
Communications (6)
A) Intel - Driver 9 /5/ 2006
B) Conexant - Driver 10/ 21/ 2005
Network (3)
A) Intel - Driver 12 / 1 / 2005
If you have an Intel chipset suggest you download AND install both Intel driver files listed above.
Burn to a CD disk. Put it in your optical drive of the needed computer. Go to My Computer, and DOUBLE-click on the drive letter, of the optical drive with the CD in it.
DOUBLE-click RIGHT ON the file name.
Follow the instructions of the Installation Wizard.
(Just click on Next, Next, and Finish)
Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP is the O/S, the ethernet chipset is the device.
When asked to restart the computer - No.
Turn the computer completely off, then after 1 minute turn it on.
(Hard Start)
Still no?
Ethernet adapter card is shot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3350631&CatId=200
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 27, 2012 | Dell Dimension B110 PC Desktop
I installed winxp on acer aspire 5720z original came with vista now i Finally got netwrk adapter correctly installed at least in device mngr no yellow! Though in network settings keeps saying disabled but...
im not sure if you can detect a certain driver you might have to go through the process
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Oct 25, 2010 | Computers & Internet
Apple USB Ethernet suddenly not functional with mac book air
I've run into a similar problem myself. The problem could be that there is another device in the area using the same frequency and is causing interference. Try changing the frequency on your adapter. If you've recently added a wireless device and you can't change the frequency on your adapter try changing the frequency on the new device or turning it off to test if it's the problem.
It's possible someone else in the area has added a device that's causing the problem look around for new wireless devices or antenna in the area.
May 27, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
My network adapter unable identfy the local network
If you are getting a 169.XXX.XXX address, it means the computer is not getting an IP address assigned from the router.
Several common things can cause this. The modem is not configured for DHCP, the cable, network card or port on the modem are defective, or even a defective ethernet cable.
hope this helps. please rate:)
Feb 16, 2010 | Sony Computers & Internet
Ethernet problem
go to the device manager and uninstall the unwanted devices.
Feb 23, 2009 | Dell Ethernet Card Network Adapter
After re-installing Windows XP, the plug and play modem is not listed as part of the hardware? Hence, cannot connect internet?
You must install the driver software if it in not listed in --- go to "My computer" >> "Properties" >>"Hardware" >> "Device Manager" >> "Modems"  make sure that modem is visible in the list if so , insure that it is not showing with a red icon... if it is ... then install the driver from the modem driver CD....
Jan 03, 2009 | Computers & Internet
My computer does not recognize the dvd/cd driver nor does the tray open without using the reset
When you say "dvd/cd driver", are you meaning the dvd/cd rom tray, or the actual system driver?
Nov 28, 2008 | Acer Aspire 3000 Notebook
Computer cant detect device
Try going to add hardware. Then select yes, the hardware is installed. When it gives you the list of installed devices, go to the bottom and select add new hardware device. After that select the advanced option to select "install the hardware I manually select from a list". On the next page, select network adapters. Then click "have disk" you will now have to put your driver in a folder(usually on the desktop). After you select have disk you will browse for the folder which has the driver. Make sure your driver has a file that has the extension ".inf" as this is needed to install the driver.
Hope this helps
May 30, 2008 | Linksys Wireless-G WMP54GS 802.11g/b...
About laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Mar 16, 2008 | HP Pavilion ze2000 Notebook
KDS Valiant 6370iPT Notebook Logo
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
