Question about Acer Aspire One PC Notebook
The notebook is on, but the screen is dark
We have the notebook plugged in, it's charged, the power lights are green, but the screen is not on.
  • 489 Answers
There is a bios update avaliable for Acer One notebook. the problem you mean is about bios update. you need to update bios. go to http://support.acer-euro.com/drivers/notebook/as_one_150.html download the bios update.
Posted on Oct 01, 2009
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | GPS
Charger makes my screen dark
GO into the control panel and check your power settings. You might have it set to use less power when plugged in.
Oct 03, 2009 | Compaq Presario Notebook
Hi when i plug in my aspire one notebook it says battery fully charged but when i unplug it goes off. the battery light is orange when plugged in can u help please
Hello elaineedd6,
There may be some settings that can allow a fully charged battery to display a green light whether or not the computer is plugged in. It might be useful to look at the power options:
•Right-Click the battery icon in the lower right corner of the screen.
•Click on 'power Options'.
•Click an option on the left side of the power options window.
It's ok to change and select different settings to find out which ones work for you.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
The notebook will not boot up. When the button is pressed, it lights up for about 10 seconds and then goes off. There is a faint hum which sounds like the fan starting up but that also stops when the...
sound like you have power problem mostly that is happen to the hp notebook now to solv
now you need to unplug the ac power and also remove the battery and press the power button and hold untell the light come on and plug it back in and also put your battery back on the notebook should work normal again
Dec 10, 2008 | Acer Aspire 7720 Notebook PC
How do i charge my garmin 750
Plug the charger into the mini-usb jack. The unit should turn on and when you come to the main menu, you should see a lightning bolt over the battery bar graph. This indicates that it is charging. If you don't plan on using it and want to charge it over night, if your Nuvi has a push down power switch on the top, press and hold it briefly until it goes to a black screen and says charging. If your Nuvi has a slide switch, slide it to the left until you get the same charging screen. A few seconds later, the screen will go dark but if you touch the screen, it will light up again and say its charging and go dark again. After several hours, when you go to touch the screen it will say Charging Complete". Yiu will also notice then when you go to use it, you will see ALL of the green bars on the battery bar graph will be lit.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin Nuvi 660 GPS Receiver
New 350 garmin, how long do I charge it Ac ?
Plug the charger into the mini-usb jack. The unit should turn on and when you come to the main menu, you should see a lightning bolt over the battery bar graph. This indicates that it is charging. If you don't plan on using it and want to charge it over night, if your Nuvi has a push down power switch on the top, press and hold it briefly until it goes to a black screen and says charging. If your Nuvi has a slide switch, slide it to the left until you get the same charging screen. A few seconds later, the screen will go dark but if you touch the screen, it will light up again and say its charging and go dark again. After several hours, when you go to touch the screen it will say Charging Complete". Yiu will also notice then when you go to use it, you will see ALL of the green bars on the battery bar graph will be lit. No, you can not overcharge it.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 350 GPS Receiver
Not powering up
sound like the power connection may have broken therefore not allowing the unit to switch on or charge.Do any lights flicker when you plug it in?
Replacement part should do it
May 09, 2008 | IBM ThinkPad T20 2647 Notebook
Acer Aspire One  PC Notebook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
