Question about RTO PasLode 900420 Impulse Framing Nailer
An activates fan activates when nib is down and trigger is pressed. no nail fires help|| on 2 years od|
  • 10,865 Answers
Check to be sure that there is not part of a nail jammed in the gun. If not, use some WD-40 or other lube to lubricate the path of the nails. You may want to take the entire head assembly apart, look for crud and remove it then lube each piece as you reassemble it. And always put a couple of drops in the air intake of the gun each time you use it.
Posted on Sep 30, 2009
My NT65AB is double firing every 4th to 8th fire, is there an adjustment on the trigger?
Chris, you will have to check your manual to see if your make and model has adjustment. Double fire is normally caused by one of three things,
1. The nailer is not being held down with enough pressure when the gun is fired.
2. Triggers valve is leaking and not releasing fast enough for a single shot.
3. The pressure fire feature on the nose of the gun (if applicable) is faulty.
If adding pressure does not help, then it is most likely faulty trigger, replace it. For guns that use a press-and-fire system, the spring in the nose of the gun may be worn, causing the double fire of nails.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Diagnose Power Air Nailers
nailer double nailing
http://www.mastertoolrepair.com/images/How%20to%20Repair%20you%20Nailer.pdf
May 23, 2016 | Air Tools & Compressors
Gun fires 2 or 3 naiks everytime I pull trigger
Most nailers have two types of triggers available. One is a bump fire and the second is single shot that is activated by releasing the trigger, placing the contact foot against the work, then depress trigger. Bump fire trigger May fire two nails if you place then depress. Check your parts manual to determine which trigger is installed. (Some brands have built-in switch to activate bump) good luck
Jul 13, 2015 | Air Tools & Compressors
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
I bought a Harbor Freight 34 degree Nail Gun, model 93099. I shot about two clips of nails, but now when I press the trigger, I get a blast of air. I removed the safety trigger and (carefully) pushed in...
if its oiled, then take all the nails out of the track and chamber, check to see if your firing valve is stuck( it is suppose to go up and down , opening and closeing the cylinder, but sometimes it gets stuck) first press the safety in all the way ( you may have to pull the feeder down ) then press the trigger , then hook the hose to the gun in that order this will sometimes unstick the firing valve
Feb 04, 2010 | Air Tools & Compressors
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
124 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
