Question about Sony Bravia KDL-42V4100 42 in. LCD TV
Sony bravia kdl-42v4100 no picture no sound if i disconnect cable running from controller board to main tuner board i get sound but no picture and if i plug it back in you see a picture for a second then the power light goes out and the red standby light blinks two times over and over
    Novelist:
    Champion:
  • 210 Answers
Sounds like there is a short on the power board or the power board has gone faulty.
Look on the power board to see if any of the capacitors are bulged or if there are any other components burnt out. The TV is going into protect mode because of an over current, which points to a short on the board or a component has gone short circuit.
Thanks
Posted on Oct 01, 2009
KDL42V4100 NO picture but there is sound. I have my surround sound hooked to the TV therefore I can hear the TV. Can you help me with this?
thanks
Posted on Jan 22, 2010
How do I brighten a Bravia KDL-42V4100
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 08, 2016 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony bravia no pictur no sound, green light comes on when i hit the power and stay til i turn off
main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 21, 2014 | Sony Bravia KDL-42V4100 42 in. LCD TV
How do I get a US Sony Bravia KDL-42V4100 to work in the UK?
I have encountered this before---there are set top boxes that will convert the NTSC to PAL and the only other concern is the line voltage being the same or not.
May 29, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Tv turns on has sound
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
Jun 24, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
No picture, red light flashing
Power supply board is dead.Replaced the power supply board well solved this problems.
Feb 17, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
KDL-42V4100 bravia - no video output.
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Jul 11, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony Bravia KDL-42V4100 42 in. LCD TV Logo
696 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
