Question about Nikon COOLPIX L4 Digital Camera
Card cannot be used error message.
I turned my camera on and I get the message "card cannot be use" I have many pictures on this card and all of the sudden I receive this message. How can I retrieve the pictures off the card?
  • 3 more comments
  • mgolechha Jan 02, 2008
    I have the same problem. I opened the camera and it started working. But when i put the screws on it stopped working. I am not sure why.
    Manish G.
  • terimony Jul 06, 2008
    My camera reads warning card can not be read. help
  • bhagenbeek Aug 16, 2008
    I also have a Nikon cam, but is also says it. But when I went down to the shop and they placed another SD-unit in it, it suddenly worked again. So it has to do with the format of the card.
    You'll have to format it to a Nikon format I guess
  • Anonymous Mar 13, 2009
    my sandisk 256 memory card says "card cannot be used" message
    but i have lot of picture on this card
  • denisebai471
    denisebai471 Feb 01, 2013
    This Card Cannot Be Used.....is the message I keep getting when I turn my camera on. It is the original memory card and I don't keep any photos in the camera, I delete them as soon as I download them into my computer. Why am I getting this error?
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
Having to format picture card evertime turned on Card not initialized
plug the camera into the usb cable or use a card reader and reformat thru your computer.
Mar 25, 2008 | Cameras
Lens error message
If the pictures are on an SD card you can simply remove the card and use a card reader on your computer to copy the pictures off.
Stores will often also have picture printers that can read the SD card.
Mar 08, 2008 | Vivitar ViviCam 5385 Digital Camera
ERROR MESSAGE: Corrupted CompactFlash card.
Storing digital picture information to a CompactFlash card (as when a digital image is taken) is similar to storing data on the hard drive of a computer -- if the process is stopped or interrupted, the information stored is not complete and, therefore, "corrupts" the storage media. A computer will display a warning message indicating that the hard drive has errors, while a camera will display a message indicating the memory card is corrupted. The CompactFlash card corruption can be caused by: * Turning off the camera power before the photo information is completely stored on the card. * Removing the card before the photo information is completely stored on it. * Taking a second picture before the camera has finished storing the previous picture. * Camera batteries that are near the end of their life and need to be replaced. Once a CompactFlash card is corrupted, it can be used again only by performing a Format procedure. IMPORTANT! When a CompactFlash card is re-formatted, any pictures stored on it will be lost forever and cannot be recovered.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
"Memory card is full"
This error message indicates that there is no more space on the memory card in the camera. To resolve this problem, do one of the following: Turn off the camera and insert a new memory card. Transfer or delete pictures from the memory card. Change the storage location to use the internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
780 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
