Question about Sport & Outdoor - Others
Cant find a deerslayer barrel for ithaca37 - Sport & Outdoor - Others
  • 10,865 Answers
Hello. you can buy it on line directly from ithaca. Go to this site
http://www.ithacagun.com/
Posted on Sep 30, 2009
How to remove a barrel lock
Push in on latch while removing barrel
Sep 02, 2014 | Cars & Trucks
Key broke in barrel
Hi Debbie, pelase contact me and i can supply you a new low cost barrel with institutions on how to fit it.
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Pride Go Go Elite Traveller Plus 4 Wheel...
Broken key in ignition vauxhall astra van 2000
Assuming you can still turn the key, take off the shroud/casing around the barrel, turn to position 1 and there is a little hole in the metal surround, press in the hole with a point of small flat screwdriver and the barrel will come out. If you cant then its a bit more difficult and may result in a 2nd hand steering column
Feb 11, 2014 | Vehicle Parts & Accessories
Assassins creed 3 at one point wont let me select gun when that is what i need
I had the same problem as you. All you have to do is place your curser over the red barrels and then it will allow you to shoot.
Nov 03, 2012 | Microsoft Xbox 360 Console
Eruo cylinber lock on one side of french doors jammed and cant open it and cant get the barrel out can anyone help
does it have a keyhole both sides ?
If so, you will need a Locksmith to pick the lock open first.
Oct 24, 2012 | Yale Locks As3535pb 35Cm/ 35Cm Anti-Snap...
Changing a peugeot 306 ignition barrel i cant figure out how the release mechanism works any help
you need to push on the pin on the side of the barrel while slowly turning the key until pin pushes through.
but if the barrel is being replaced you will be able to drill through the locking pin
if this was any help let me know
cheers
mike
May 26, 2010 | 1998 Toyota Corolla
Theirs a pellet stuck in the barrel and no matter what, i cant get it out
Get a wood dowel that will fit snugly but still loose in the barrel. Spray a little PB blaster in the barrel and let it sit on the pellet for about 30 minutes,then use the wood dowel with a small mallet to drive the pellet out.
Sep 01, 2009 | Crosman (4032)
Oil pressure gauge moves too much
Have your oil sending unit checked, this part is not to expensive
Jun 16, 2009 | 1994 Jeep Cherokee Country
I HAVE A MERCEDEZ 190 AND THE KEYS ARE NOT TURNING IN IGNITION BARREL NOW THE STEERING IS LOCKED ALSO I HAVE TAKEN OUT IGNITION BARREL WITH STEERING COLOUM. i WOULD LIKE TO DISINGAGE THE IGNITION BARREL...
it is better to buy a new ignition barrel.it takes a special socket to get the screws out, once the screws are out they do not need to be replaced.buy new barrel,disconnect negative battery cable,disconnect wires from barrel assembly, remove barrel from colum. first take vin# to dealership parts department to get correct barrel assembly, the keys with new assembly will fit doors and trunk
May 19, 2009 | 1993 Mercedes-Benz 190
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
