Question about Hotpoint Dryers
The dryer makes a grinding noisse when its running
Getting inside the heating element
  • Hotpoint Master
  • 7,482 Answers
The grinding noise you mention sounds like a drum roller needs lubricant or replacement.
If it is a front loading dryer, remove the front of the dryer, that will expose the drum, remove the drum and that will expose the drum rollers.
I would try to lubricate the rollers where the roller attaches to the shaft with a good grade of machine oil as 3 in One oil.
I hope this helps
Posted on Oct 01, 2009
Samsung DV422EWHDWR/AA is not drying,and makes grinding noice
One witch rollers is broken and next heating element is broken when heat is not coming inside.
Dec 10, 2016 | Samsung DV422EWHDWR/AA White Electric...
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
No heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Whirlpool LER5636P Electric Dryer
Frigidaire dryer AEQ7000EGO not heating up
you need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Sep 12, 2009 | Frigidaire AEQ7000ES Dryer
No heat on dryer just air.
2. Heating element
3. Thermal fuse
Jul 12, 2009 | LG DLE2532W Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Jun 02, 2009 | Whirlpool Dryers
Heating Element rattling
I would not run the dryer and check the wires to the element and make sure there are no burned wires. I would also replace the heating element. It should not be loose in any way
Jul 27, 2007 | Maytag MDE2600 Electric Dryer
Dryers Logo
76 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
