Question about HP DeskJet 5550 InkJet Printer
Printer has problem with printing document. It feeds a little at a time but hte ink cartages don't move.
When I do my alignment after putting in new cartridge it says to align the head. what do i do?
Posted on Sep 30, 2009
Our printer will use the copier and scanner function fine but when we try to print some thing out it will not use any ink. we replaced both ink cartage black and color. All colors work when we copy or scan...
Do give the ink some time to come through, gravity will do the rest.
You could clean the ink heads to get the ink to come through quicker.
When printing the document, go through the settings and see if you see anything to do with the darkness of the print.
damnor01
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My ink carrage keeps slamming into the side and the message is to clear the area but there is no obstruction. The printer will begin a page then abruptly go either left or right and slam into either side...
HI
It is because some time of the other it has moved on the belt where the inks cartages slides on the bar.
You can try to get it to stop in the middle of the bar do this by printing some thing and as it starts printing switch off at the power so it will stop then push it over a little bit to the other side by hand not to much.
But don’t push it to hard then restart the printer and see if it any better you may have to do this more than ones till you get it right.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Feb 05, 2010 | Dell 942 All-In-One InkJet Printer
How to refill hp564 ink cartages?
Please, do not wast your time doing that. Re-filled cartridges can cause a myriad of print quality issues. They also may be grounds for the printer manufacturer to void any remaining warranty that may be left on the printer.
I know that these vendors will the ink is fine but nine times out of ten the chemical signatures of the ink will be different.
Protect your printer and use the ink sold by the manufacture. Its not worth throwing out the printer because the ink damaged the print head or does not flow properly.
Don
Jan 22, 2010 | HP Photosmart Premium C309A All-In-One...
My canon bjc 3000 inkjet printer is feeding paper but not printing. Does the head need cleaning? How is this done?
could be possible that its either dired up or out of ink, open its bonet and remove cartages, clean head with a soft cloth removing any dried ink give cartages a good shaken see if any ink comes to head, and try again. hope this helps
Nov 30, 2009 | Canon BJC 3000 InkJet Printer
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print cartages won't move when I open to change.
You can manually move a printhead( the one that holds the cartridges) to the center. Open the door at the back, turn the wheels clockwise, and while turning, manually move the printhead to the center..
Apr 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP DeskJet 5550 InkJet Printer Logo
Seeker5211
Seeker5211
