Question about Garden
Do you have any info on lawn mower carbs?
I have a craftsman rotary lawn mower that surges badly. took carb apart a few times to clean. not familar with this type of bowl/float less carb. any ideas?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello, do you know what brand and hp of engine
    Scholar:
  • 110 Answers
If this is a carb-on-the-tank Briggs engine, replace the rubber diaphragm that fits between the carb and the tank. Almost certain fix.
Posted on Oct 01, 2009
Starts up fgor few minutes then shuts off
Clean or replace air filter. Ensure oil is full. 30w. Remove bowl from bottom of carb & clean. Clean carb.
Sep 07, 2013 | Cub Cadet Garden
Toro 20056 no start
check for movement of the solenoid on the bottom of the carb and also check for power
May 21, 2012 | Garden
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Feb 08, 2012 | Craftsman Garden
Describe your Briggs Stratton Lawnmower Lawn Mower Short Block Problem. I have model# 11A-414E765 Lawn Mower. Starts ok but is surging and when I checked a brand new spark plug it was full of black dust...
I am pretty sure this is a 4.5 Hp engine with the carb on top of the tank. Plastic carb 4 or 5 mounting screws mating carb to tank. Remove the air cleaner... and tighten the carb to fuel tank mating screws. It is drawing air between the tank and the carb. This should stop the surging. If is has been a long period that you used the mower with the surging problem the diaphragm between the tank and the carb may be either out of position or damaged. The diaphragm is not expensive. Usually the first time this symptom presents itself you can resolve it by tightening the carb to tank scresw. IF you have the primer bulb carb..mash the rubber of the bulb against the carb body. If the surging stops... the primber bulb has a pin hole in it.
You passed the mower model number and not the engine model number. When we use the 11A number you passed all we get is the base and handle parts. If you need more help I need the model number off the engine just above the spark plug wire on the air shroud.
Thanks for choosing Fixya,
Kelly
Aug 31, 2011 | Briggs & Stratton Briggs Stratton...
Mower surges its a 5.5hp craftsman mower
Carburetor possibly needs cleaning. Initially, remove air filter, start mower and while it is running, spray some aerosol carb/choke cleaner into the carb thru air intake area. Continue doing this several times but not too fast or heavy to make it stall and then spray it heavily until engine dies. Let it sit for several minutes and then try a restart. If no difference in performance is noticed, carb may have to be removed and cleaned in bath-type cleaner and governor settings will need to be checked also.
Please vote on this solution.
Sep 13, 2010 | Craftsman Garden
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I have a 2003 craftsman 6hp lawn mower. It would start and not stay running so I cleaned the spark plug, cleaned the carb and drained the fuel. It ran decent for a mow, the next time I used it I started it...
Fuel Problem, Pull off the Carb bowl you will see the problem (Green Gunk and Varnish. When you drop the Carb Bowl you will see a hole in the carb assy. below the float, use a paperclip or other small object to clean it out........its probably plugged.
Jul 12, 2009 | Craftsman Garden
Engine is surging.
hi,
sound through experience you have a air leak possible from a gasket or oring if so equipped. take some wd 40 and spray around the carb gaskets and seams. if this stabalises the surging or smooths it out it is definatley seeping air around it. in any case you will most likely need to take the carb back apart and repair or replace the gasket. hopes this helped. happy mowing!
Mar 29, 2009 | Craftsman Garden
My craftsman rotary lawnmower wort start i changed the spark plug
a mower will hold 20 oz of oil. however most times it is changed you do not not get it all out. so only 16 oz is needed. if you overfilled the oil. this would cause hard starting. or did you have the mower tipped on it's side for to long, oil can sometimes seep past the piston out thru your intake valve and into your carb as well as destroy you air filter. you might get by with a new oil change and a carb cleaning.
also has this unit been sitting for a while does it have fresh gas. and No water in the tank/carb
Mar 16, 2009 | Craftsman Garden
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
