Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Same exact problem, paper stops a few inches and has to be removed. Wont print anything without jamming.
  • 68 Answers
Try to pull paper tray out and clean the feed roller with alcohol or water.
Posted on Oct 04, 2009
Magicolor 2400w top margin off
I spent a while troubleshooting a similar issue on my 2400W. It turned out to be the SL2 registration solenoid, which failed to engage properly. The purpose of SL2 is to stop the page temporarily until it lines up with the image on the transfer belt. Unfortunately, SL2 is very finicky, the foam pad that stops the lever flattened too much and got sticky, so the lever wouldn't engage anymore, and the paper went straight through instead of pausing briefly when using B&W mode driver, resulting in the shifted image. In color mode, I got no image, just a "paper jam at transfer roller" error message, even though the paper came out empty without jamming. I had to adjust SL2 a few times to get it to work optimally, i.e. with minimal travel and maximal holding force. Then everything worked well again.
Jul 28, 2012 | Minolta magicolor 2400W Laser Printer
Tip
My epson cx5900 wont print anything. it takes paper in, the head moves by a few...
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
  • Work directly with CSIC in EPSON Stylus printers cartridges.
  • Reset or rewrite any chip using special add on device.
  • Freeze internal ink counters.
  • Reset internal ink counters even with empty cartridges.
  • Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
  • Hot swapping of cartridges supported.
  • Resetting of protection counter (even then it is already full).
  • More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
Click here for the EPSON Ink Pad Reset Utility
on Jun 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer stopped working
When you removed the paper did you rip it? Maybe you still have a piece of paper inside printer. You can also try shutting down the printer and canceling the print job and retrying it again.
May 31, 2010 | HP DeskJet F4280 All In One Printer InkJet
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
DUPLEX PAPER JAM
I posted previously. After buying new paper, the duplex printing is working. It is probably heavier than my previous paper, but not particularly thick (don't know the exact grade.) So if you have this problem, try buying some new paper a little thicker than you are using now.
Apr 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
235 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
