Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I got a used router but have no disc. want to put security over network but cant find anything saved on pc
  • Jaipal Nair May 11, 2010
    please give the model number and make of the router
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 02, 2009
I cant put safety as
Are you trying to secure the wireless network?
For this you will need to access the router setup page and change the settings manually.
See how to secure wireless network.
If you are not able to save the settings then I will suggest you to upgrade the firmware of your router. The reset the Linksys router and reconfigure it manually.
Create a new wireless network. Change the name of the wireless network that you never used before.
Then try to connect to the new wireless network.
See How to reset Linksys router.
See Linksys router setup
Jan 22, 2012 | Linksys Wireless-G WRT54G Router
I have just gone on to wireless and its asking for my security key? Where will i find out what my security key is????
Hi, your security key, is the Key, that was generated in the router when you were setting up the router for first use. First, you put in your user name & password, then you go to security settings and set your WEP/WAP Key, this is the security code that must be used to logon to that network from the WiFi.
Now if you either have an unsecured network, or an unknown WEP/WAP key, what you have to do is, Login to the Router with a browser, and get through to the security settings, and Generate a Key, now when you generate the key, copy/paste this Number to a notepad document, save it somewhere handy, say desktop. Now finish off with the router, save all the settings and reboot the router, now you are ready to logon to your wireless network, now startup the PC, and find the SSID, The name you gave your WiFi connection, now when you select, you will be asked for the WEP/WAP Key, open the notepad document and copy/paste that number you saved into the place provided, there, now you have your security set and be able to logon to your WiFi & router.
It is all also explained in your user manual, i have included a copy below.
http://www.retrevo.com/support/Netgear-DGN2000-Wireless-Routers-manual/id/23021ci772/t/2/
Sep 04, 2010 | NetGear DGN2000-100NAS Router
I have lost my security code and cant use wireless
http://en-us-support.belkin.com/app/answers/detail/a_id/48
all routers have reset button on them, you can reset the router to the factory settings and set up yor wireless with the new code
Jun 19, 2010 | Belkin (F5D8231-4) Wireless Router...
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
I want the password to put the secure code
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
If you already set the code then if you can read it then you can ser it in wireless but if it is in 8 or # format then add new wep code .
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Jun 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have LINKSYS wireless router, mod # WRT546 in my home for my PC. My internet connecting has gotten very slow and a friend advised other PC might be accessing my wireless and I should password protect my...
http://192.168.0.1
or
http://192.168.1.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Feb 09, 2010 | Linksys Wireless-G WRT54G Router
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Jan 25, 2009 | NetGear WGR614 Wireless Router
Do I have to lock my D-link router connected via Ethernet cable? If so, how do I find the router on my PC?
Ya you should lock it with password .. bcoz.. if you will not lock it other might access it and it may harm you in some way.. they might access your internet resources , or data .. or anything they can do with your network settings with that router...
Connect to your router with your browser. then you will find a wireless security tab over there... click on that tab and you will find that the security features are disabled.
You should have several options when it comes to the type of security that you can choose. I prefer WPA, it allows you to simply enter a password to access your wireless network. This password can of course be saved in your wireless settings so there is no need to enter it but one time.
Simply enter your password in the password box and hit save. Your wireless network is now secure. Distribute the password to anyone that is allowed access to your wireless network.
Aug 22, 2008 | Computers & Internet
Unsecured wireless network
what router do you have?
make and model
Feb 28, 2008 | MSI Wireless-G RG54G3 Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
