Question about Kyocera Copystar CS-1620 Black and White Copier
Print on black line
How to pullout the drum unit
  • Anonymous Dec 20, 2007
    Can you send me KM 1620 Error codes and its solves simmulatio number.
  • 54 Answers
You have to remoe the toner cartridge, then the developer section (one screw) then the drum unit (one screw also) Make sure you have the left side door open when removing drum unit.
Please don't forget to rate your answers please.
Posted on Dec 20, 2007
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Canon 2016, vertical black lines.Print and copy, not always
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Aug 14, 2013 | Canon imageRUNNER 2016 All-In-One Laser...
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
I channged toner in my sharp sf-2022 copier, now i have black smudge-like marks going across paper & the copys are real light begin to fade 1/2 way thru page? cleaned 1 of the rollers, helped a little...
Open front cover, you will see yellow knob, pull it down and pullout. Wipe the side with mesh with clean cloth and insert back. That's the main charge unit.
Pull the green lever to the left and pullout the transfer charger . Wipe the two wires carefully not to break them and insert back.
Do not try to remove the drum if you have no skills otherwise this should solve your problem.
Dec 10, 2009 | Sharp AL 1631 Copier
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Head cleaning
This is that the black drum unit cleaning blade failed or the charge roller has toner stuck on it. To remove the drum open the front cover and using the green tool right hand side of opened door undo the two screws turn the transfer lock into the unlock position and lift. Once you have done this then remove the black drum this is the one at the top by moving the little green tag to one side and pulling out (Be Careful as if you scratch the drum you will have other problems)
Once remove you will be able to see the drum and a black roller above it see if that has the black line on it. If it has then clean with some alcohol based cleaning fluid once this is done reinstall and then print. If there is no line on the black roller try above the likely thing is that the drum cleaning blade has worn and the unit will need replacing.
Glad to be of some help
Thanks J
Dec 10, 2007 | Ricoh Aficio AP3800C Laser Printer
Poor Print quality - black lines appear on page
If you see black lines on the drum, it is very likely that the drum unit is bad. Replace the drum unit and rest the drum counter. If you wait too long, you will cause toner build up in the fuser and will cost yourself several hundred dollars to get it replaced. More in labor than parts.
Use a soft cotton or very soft paper towel and wipe the excess toner from the drun. If there are lines worn in the surface of the drum, then replace it ASAP.
Nov 15, 2007 | Sharp FO 4450 Laser Fax
Kyocera Copystar CS-1620 Black and White Copier Logo
115 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
