Looks like the colors are not aligned. When you look at a word on the screen it looks like it is out of focus mostly on the bottom portion of the screen
  • 336 Answers
Hi,it sounds like an issue with the Dmd board ,this is how it works: http://www.fixya.com/support/t3066225-while_watching_tv_moment_ago_screen Test if it is that by displaying the menu and if its affected that's what it is.Also check for "whining, whirling, clicking, or humming noises if it does that it will be the color wheel, which is a disc looking that has a motor that spins it at high rpms and the light of the lamp hits and creates the colors on your tv.God bless you.
Posted on Sep 30, 2009
Red color does not align
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Televison & Video
How to fix when out of focus?
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 03, 2010 | Panasonic PT-51DX80 51" Rear Projection...
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
60" hitachi 60SDX88B screen shows some green distortions in the top and bottom of the screen. Magic focus does not fix this. Help?
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Dec 21, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
Oct 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Yellow arch on bottom left of screen
*Screen Looks 3-D
*Colors wont align
Problem #2
Sep 30, 2009 | Toshiba 43H70 43" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Jul 13, 2009 | Samsung PCL5415R TV
Hitachi 50ux26b/27k with AP63 chassie convergence problem
It looks like the STK chips need to be replace for fix the distorted colors.
You can download the service manual from here: http://www.eserviceinfo.com/downloadsm/11792/Hitachi_60SX12B.html
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
