Question about Refrigerators
The ice forms on the tubing behind the back of the freezer, causing the refrigerator (top) to get warm. We take the inside back off and melt the ice. It works til the next time. What part do I have to replace to fix this? thanks Eleanor
  • 308 Answers
Your defrost timer, most likely
Posted on Oct 01, 2009
Samsung rf265abpn ice forming behind Fresh food fan, ice filling up funnel under cooling unit, was told to hang a piece of coat hanger off heat coil.
Hi Mike,
You could have an outside airleak which would let in warm moist air into the freezer.OR the condensate drain tube is plugged up or frozen up. thats the drain tube that drains the melted ice from the freezer OR the condenser fan located buy the compressor is not running. Check all drain tubes and drain channels for clo-
ging or freeze-up due to improper and complete draining.
Oct 20, 2011 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Ice forming on the bottom of the freezer
The ice is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water drining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind teh service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
The freezer drain doesn't work and water / ice builds up in the bottom of the freezer and leaks out the bottom of the door
In the back behind the service panel is a tube that connects to the nozzle from the drain inside the freezer it can be pulled if and cleaned then also GENTLY poke a small hole in the inside part then flush w/warm water to clear.The best way i have found to clear the inside part is take a wire hanger cut&bend it and heat the tip then place inside tube so the heated tip will melt a small hole through ice so is can easily be flushed
i hope this helps
Gene
Aug 04, 2011 | Maytag MSD2732GR Side by Side Refrigerator
A substential amount of Ice forming on back panel inside the fridge. The built-in 71840 with top freezer is only 1 month old. Is it normal that allot of ice forms inside the fridge (mostly in the mid...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 03, 2011 | AEG SK71840-4i Top Freezer Refrigerator
An intermittent stream of water from the back top center shroud in the lower freezer section of our Gladiator Ref/Freezer is causing a lot of ice in the freezer. What's wrong?
This is caused by a design flaw in Gladiator Freezerators. The problem is caused whenever the auto-defrost cycle is active. This causes the frost on the coils to melt and flow to the drain tube. If the tube is blocked by ice having formed inside, the water has nowhere to go except down into the freezer compartment where it aagain freezes and forms an iceberg. The solution is to defrost the drain tube but this is only a tempo fix, because eventually it will freeze again. A more permanent solution is to remove the rear cover in the top compartment and expose the cooling coil and the defrost heater. Carefully wrap a 2-3 ft. long piece of bare copper wire, about 14-12 ga. several turns around the defrost heater and extend it down the drain tube located at the bottom right hand side of the drain tray. The little bit of heat transmitted down this wire is enough to keep the tube from refreezing. This fix is now available as a kit that Sears uses to take care of this problem but their kit does not work as well as the above. Good Luck!
Nov 14, 2010 | Whirlpool Gladiator Refrigerator
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The fridge part of the fridge freezer has a coating of ice forming at the back and it feels warm behind bottom right veggie tray
Sounds like the freezer/refrigerator circulating fan is starting to wear out, When the motor for this fan starts to wear out it does not supply enough circulation for the freezer and the refrigerator. The minimum cost to repair/replace this fan is around $300.00. The immediate solution is to unplug you unit for about four hours allowing the ice that has formed around this fan to melt. Or use a hair dryer to melt the ice, but be very careful not to melt the plastic.
Jul 11, 2009 | Refrigerators
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
