Tv powers on, then switches off immediately
VS-60607 model Power light turns on and then immediately turns off. You can hear the tv click on and off. The first time this happened, I let the tv stay off for about an hour and was able to turn it back on. It stayed on for about 2 hours and turned off by itself while we were watching it. I let it sit again for about an hour and turned back on. It stayed on for 4 hours until I turned it off. I haven't been able to turn it back on since. Any suggestions? My 60' hitachi 60sx12b has been turning itself off for several weeks now and the time between turning it on to when it turns itself off is now down to about 1 minute. When it turns itself off no lights are on the front of the TV but I have to hit the power button to completely turn the set off. If I hit the power button twice after it turns itself off the first hit just gives another click inside the TV and the second hit turns it on for about a minute. Any suggestions? Thank you.
4 Suggested Answers
  • 1153 Answers
SOURCE: tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Posted on Dec 25, 2007
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Posted on Nov 25, 2008
JayAbed
  • 14 Answers
SOURCE: Hitachi 60sx12b. when you turn on, clicking sound, don't turn on.
Replace micro fuse F903 (5amp). It's located near the biggest 2 caps. in power supply area.
Posted on Aug 24, 2009
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
Mitisubishi 60607 will come on the go right back off
you have a component failure. begin checking the on-board fuses. that should lead you to the circuit that failed. most often it is the convergence circuit. 2nd most is a loss of vertical deflection. this is a tube protection circuit that shuts the set off before it destroys the crt's.
Jan 06, 2010 | Mitsubishi VS-60607 TV
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi VS-60607 TV
My VS-60607 won't turn on
there is a fuse blown in the television keeping it from staying on. after the shutdown press and hold the menu and device/input button for about 5 seconds and the led will blink a 2 digit code with a pause in between. the code will repeat itself. 2.2 is the most common and points to the convergence ics and 1 or 2 5a pico fuses. 2.3 is the next most common and points to a fault on the power supply. goodluck.
Feb 05, 2009 | Mitsubishi VS-60607 TV
unit will power on for a second then shut off. power supply ?
Oct 27, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
Oct 07, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
