Question about Abit SG-71 Motherboard
Can not shutdown /CPU fan allways working
How can i know which shudown time is programed?
How can I see the shutdown ''code''
Can I make a shutdown step by tsep?
  • eng_pedro_p Oct 02, 2009
    thx for the post but i do not understan what do you wnat me to do. How can i see the "xx" value?
  • 329 Answers
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Posted on Oct 01, 2009
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
Fans still running after shutdown
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Aug 18, 2012 | OCZ Technology PPC Silencer 500W MKII...
When turn on my computer after a seconds the system is shutting down.. i don't know what to do, is there a problem with the processor?
A overheating CPU will shutdown and won't start up again until the CPU has cooled down.
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Computers & Internet
My acer aspire M5100 getting into shudown mode
Check the temperature of the CPU in Bios. It is probably higher than the Safe temperature and it gets into shut down mode to protect itself.
Open it, detach the cooler from the CPU and clean it, detach the CPU from the socket, clean the paste from the top, put a new one, clean the socket and put everything back. It should work perfectly.
If you need further assistance, just leave a comment. Cheers
May 23, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
I have a custom built computer w/ xp pro. my computer shuts its self off. why? sometimes it will do it 4-5 x a day, then there are days it won't do it at all. any suggestions?
Automatic shutdown can be due to mostly over-heating of the CPU or CPU fan not working properly. Blow the CPU areas plus the CPU fan with an Air-blower and check if the CPU fan is working properly or not. If the CPU fan is malfunctioning then replace it. Your system will work fine.
Make sure your system is free from virus and worms as it too can be the cause of  system shutdown (but this cases are very very rare).
That's it.
Mar 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Restore from "door open" shudown?
unit probably shut down and has to be programmed back on .check usage and care.
Feb 24, 2010 | Refrigerators
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Overheating again!!!!!!
place the fan in the most conveniant place to cool down what ever it is you want to cool ie the case
good luck
Terry
Mar 10, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Abit SG-71 Motherboard Logo
597 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
