Refrigerators
Generic problem for all Refrigerators
GE GSH22SGRE - water dispenser not working but ice...
shared by 4 users
posted by jeres on Dec 20, 2007
The water dispenser is not working but the ice maker is working fine. What could be the problem?
side by side stainless steele
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by funkieweave on Jan 04, 2008
Water won't work but icemaker does and i tore the line apart on bottom of fridge and get water out to there but it wont go up the door and out the despenser
Posted by gupton on Jan 03, 2008
i can hear the pump come on when dispenser lever is pushed but no water, replaced filter no help
Posted by Chas69 on Dec 21, 2007
ICE CUBE MAKER WORKS....WATER DISPENSER DOES NOT...AT ALL.
Solution #1
posted on Jan 05, 2008
Not Rated (0)
wiltonite
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GE GSH22SGRE - water dispenser not working but ice cube maker working fine:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
fridge is too warm, even after adjusting the setting to...
Whirlpool GS6NBEXR Side by Side...
The inlet hose going to the filter is leaking at the...
Refrigerators
I noticed the meat in our freezer was starting to thaw...
Refrigerators
refrigerator is not freezing and not cold as it use to be
Frigidaire FRS3R5EMB Side by Side...
my refrigerator is not cold as it use to be and is not...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
