Question about Maytag Dryers
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
  • 304 Answers
When a dryer goes past off and into the next cycle on the dial of a mechanical, turn dial timer the only possible problem is the timer. Replace it because the contact that should open in the timer during the off portion of the cycle has failed.
Posted on Oct 01, 2009
  • Maytag Master
  • 7,482 Answers
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
My dryer wont run the time i enter if it says 1:40 it barely runs 15 min why?
try entering 1:2 as it probably means that 1:4 is 15 minutes as the time increments is 1/4 hours in minutes
Jan 04, 2017 | Dryers
Kenmore 500 dryer used to dry a full load of cloths in 1 regular cycle of about 40 to 50 minutes. Now the same cloths are taking nearly 2 hours to dry.
I think I would check and see if the dryer vent tube is clogged or nearly clogged. It sounds to me like it is. Try this first, if its not, I will continue to try and solve this with you.
Sep 06, 2015 | Kenmore 500 7.0 cu. ft. Electric Dryer -...
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryers Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
