Question about HP Pavilion dv2000t Notebook
Blank screen no matter if my laptop is sitting open or if it is closed after i goes into hibernate mode then the screen doesnt com back if there is an easy way to fix this please let me know
  • XFISHD May 11, 2010
    What Operating System are you useing (Windows XP, Windows Vista)? Do you use an external monitor with the laptop? Consider getting the driver updates for your Video Card and updating your BIOS Pavilion dv2000t updates
    President:
  • 2,600 Answers
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Posted on Sep 30, 2009
Screen goes black close lid and open screen works fine
what configuration of the power manager do you use? laptop goes to hibernation mode automatically or by pressing the power button or by closing the lid?
Feb 04, 2014 | Dell Inspiron 1420 Laptop
What could be wrong with my pc monitor,I turned it on and the screen is blank
it is always best to be as descriptive as possible and give as much info as you can about your problem. is it a laptop or desk top? is it a new display added to a desktop? if it is a desktop and the screen is blank after you turn it on, most likely the cable to the pc is not firmly connected (i've done this many times when setting up a new system) or it could also be that the system has gone into Hibernate mode and moving the mouse or pressing the space bar or escape key could bring it out of hibernate mode. Hibernate mode goes active when the system has been idle for a long time without any keystrokes or mouse activity. hope this helps
Apr 10, 2013 | Computers & Internet
When I close my laptop during normal use, Instead of going into hibernation as normal, the screen just goes blank (with the laptop still running). However I cannot resume the computer and have to just turn...
hi when you close your laptop it goinng to stand by mode if you press any key it should resume. you can change this options in control panel, power option then go to advanced tab. By the way hibernation need to be enable and is different than normal shout down. if you need more help let me know.
is it help please rate it
regards
Sep 06, 2010 | Computers & Internet
Screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Nov 15, 2009 | Computers & Internet
Inspiron 1525 pisses me the ********
This is a problem with the BIOS of your laptop. You can do a BIOS upgrade by downloading the updated BIOS from the laptop manufacturer's website. If you close the lid and your laptop goes to sleep mode, your downloads will be halted since you system will go on to power savings-mode (most nics are disabled during this mode). What you can do is let your laptop sit during downloads but change the power savings mode to always on (RC on desktop>properties>screensaver>power>power scheme is always on).
Jun 25, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
HP Pavilion dv2000t Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
