Question about Craftsman Tools & Hardware - Others
Where can I get a PDF copy of the owners manual for the Craftsman All in One Cutting Tool Model # 183.17254? (AC Rotary Trim-Cutter)
  • 2,176 Answers
Go to Managemyhome.com and under manual type in your model number and after the 4 add a 0. The manual is 37 pages long. If I have helped you with your request would you please rate this reply accordingly and Thank you.
Posted on Oct 03, 2009
Testimonial: "Thank you very much. This Manual was difficult to find and you helped get it. Much apprciated."
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
Tsp100 not cutting receipt
the Auto-cutter on that model is only a 'partial' cut, (Guillotine-style.)
Since it is an Auto-cutter, if it is not cutting AT ALL, that is not something that a "user" can adjust-for.
See section 7-3 Releasing a Locked Cutter (pg 26) in your manual here:
http://get.acclivitysoftware.com/copdfs/TSP100PrinterManual.pdf
Nov 02, 2012 | Star Micronics TSP100 Thermal Printer
Have a MODEL 572.610530 CRAFTSMAN ROTARY TOOL. TURNED ON UNIT AND BEFORE I STARTED USING IT, THE TOOL SHUT DOWN. I EVEN CHANGED OUTLETS TO MAKE SURE IT WASN'T THE OUTLET...IS THERE A WAY TO RESET TO...
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
May 18, 2011 | Craftsman Tools & Hardware - Others
I need a manual for a craftsman all-in-one cutting tool. The model #183.17254
The site you go to is Searspartsdirect.com and on the right side type in your model number and just follow the links to the manual I looked at it and it is 37 pages long. Let me know if you need more help. If I have helped you with your request would you please rate this accordingly and Thank you.
Sep 12, 2009 | Craftsman Tools & Hardware - Others
How do you attach a wheel cutter to a dremel 400 xpr
Go to Dremel.com and download an owners manual for detailed instructions for this tool.
Jul 07, 2009 | Dremel 400 Xpr Rotary Tool
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Tools & Hardware - Others Logo
1,807 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
