Question about Canon EOS 450D + EF 75-300mm lens Digital Camera
Canon eos 450d. When switched on, the display does not show ie shutter speed, battery level, iso etc etc. It works fine when the auto display is disabled and can be switched on and off using the disp button on the camera body but will not come on when it is enabled.
  • 24 Answers
Check whether there is anything obstructing the range sensor just above the rear LCD. The sensor could be thinking that your face is near, thus turning off the display. Also, you should be able to use the Disp button even in auto display mode, which might make the display not show anything by default.
Posted on Oct 01, 2009
I have a Canon PowerShot SX 10 IS. In Manual mode shows only black screen with icons. In Auto mode everything is fine.
Dear Olia,
Just a quick check on your camera. You have a focus issue so check the settings for the ISO - increase the value, eg. 800 or above and reduce the shutter speed. You can do that by the quick access dial (wheel) facing you. There are four direct access menus in a criss-cross direction. One is assigned to shooting mode - single, multi, timed etc. The other direction will have macro, standard, telephoto etc. the 3rd direction will (towards right) will take you to the ISO settings and the last will take you to the shutter speed settings.
you manipulate the ISO and shutter speed and see your screen will brighten up and the subject will be clear. Refer to the picture attached.
Hope this helps.
Oct 18, 2015 | Canon PowerShot SX10 IS Digital Camera
Canon 450D Main dial not working
Spillage or impact damage that breaks lands in the flexible top cover circuit can cause this problem, as can sand which wears away traces on the switch contacts on the circuit itself. Impact can also cause the flex from the top cover topull loose or twist sidewase in the flex connector on the main circuit. In most of the Canon Rebels the top covers are only available as complete assemblies.
Feb 02, 2013 | Canon EOS 450D Digital Camera
No display nor will it shoot
SHUTTER IS FAULTY YOU NEED TO REPLACE NEW ONE
Jul 11, 2010 | Canon EOS 450D Digital Camera
Canon EOS 450D Can only get the Shooting Setting Screen no image
In picture taking mode, press the "set" button for "live view".
Feb 27, 2010 | Canon EOS 450D Digital Camera
Have a EOS 450D When I take a picture it says busy for a good 1
Switch to Shutter Prioriy (S) and set the shutter speed to what you want it should be at least 1/60th of a second.
Jun 12, 2009 | Canon Digital Rebel / EOS-300D Digital...
Use in canob 450D
No. You can only use the camera in manual mode, setting the shutter speed to, say, 1/125 sec and the aperture: according to the working aperture on the flash. The flash has to be in auto mode. The physical connection between the camera and flash can be either a standard PC cord, originally supplied with the flash plus a hotshoe-to-PC-female "cube", or an SCA305a cable plus an SCA301 standard foot. Of Metz 45 series only the 45CL4 Digital together with an SCA3102 M4 module is dedicated to the Canon EOS digital series.
Sep 01, 2008 | Metz 45 CL-1 Flash
I have a canon eos 450d which on the display screen only shows the information I can't see what I can see through the view finder, help please.
you have to enable the live view from the menu. then press the set button on the center of the arrow keys.
when shooting with the live view on, auto focus will not work if you press the shutter button halfway, you should press the button marked '*' to make the auto focus work. the small rectangle on the lcd monitor will turn green when correct focus is achieved.
Jul 07, 2008 | Canon PowerShot A530 Digital Camera
Shutter display problems
I hope if the camera set for auto then there would be no speed display
If the batteries are good then the LCD panel should be given attention
Feb 10, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS 450D + EF 75-300mm lens Digital Camera Logo
226 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
