Question about Aiptek MPVR Digital Camera
Black screen When I turn on my camera I can hear it coming on and while its on I can hear recordings but I have a black screen. Please help
  • bernii Oct 11, 2008
    When I turn the camera on the lens does not open.
Its ur sd
Posted on Aug 14, 2008
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Black screen when recording.
I would check to see if the cable to and from the lens assembly had come loose. If so resecure it carefully and this should take care of your problem . Larry's Electronics repair.
May 10, 2010 | JVC GR-D270US Mini DV Digital Camcorder
I have a JVC digital video camera (Mini DV). the screen is all black, it can still record but only a black screen. it recoreds sound only. the screen tells me to take off the ens cap when it is already....
I want you to do this to confirm which part has a problem. Look at your camera lens directly face to face and observe those tiny shutter inside while switching on your camera. You must see the movement of those tiny shutter and even hear some clicking, if so, CCD replacement is needed. Sometimes those shutter stacked up and shows the same symptoms. Hope it helps
Jan 29, 2010 | JVC GR-D30U Camcorder
Nikon Coolpix s550: Screen won't work
Please make sure no cable is attached to the camera. On many Nikon cameras, connecting a cable shuts down the screen.
Oct 05, 2017 | Nikon Coolpix S550 10 Megapixel Digital...
Lens Cap Error
You have a defective CCD imager - the part of the lens that receives the image. Will need to be replaced.
Aug 03, 2009 | JVC GR D650US camcorder
Sony dcr-dvd105 no sound
Try this:
Play back a recently recorded scene through the viewing screen. Make sure any "mute" setting is turned off and turn the volume up. If you can hear the sound, the problem is not in the camera. Also, run through your menu's audio settings to make sure that they are set correctly.
If you can't hear any sound, repeat the process with an external mike attached. If this gives you sound, the camera's built in mike is defective. Time to hand it in for repair.
If you still can't hear any sound, something else is wrong with the camera. Again, send it in for repair.
Jan 09, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
My Quasar VM-L143-C Camcorder screen turns black
if the camera records the video it will be there in the memory of it and you can check it by connecting it with a computer.if the video is in the memory there will be no problem with the recording device and the problem will be only to the LCD screen .if it is so, replace it with a new one which cost you about 35$-40$.if the settings are not correct the above problem will occur.so check the settings first and then go for the replacement of LCD .check whether the color of the LCD screen is in the correct level(check the brightness,contrast....)thank you.
Dec 17, 2008 | Quasar VM-L153 VHS-C Camcorder
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Black Screen
What is the camera model number?
Mar 19, 2008 | Samsung SC-D365 Camcorder
Camera is on but LCD screen and viewfinder are both black
1. Press display (DISP.) button to turn the display on Do this when your camera is on and in shooting mode. This should fix the problem. I had to try it a couple of times before it worked.
Dec 22, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Aiptek MPVR Digital Camera Logo
66 people viewed this question
Top Aiptek Cameras Experts
ray gallant
John Oughton
John Oughton
Level 1 Expert
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
