Question about HP Pavilion a450n PC Desktop
Will not power on. Light on the back below power cord is flashing. We had a power outage yesterday, but it worked fine afterwards. I'm no expert, but I presume it's my power supply. o one seems to know where I can get a replacement.
    Sergeant:
    Champion:
  • 212 Answers
Had the same problem once. replaced My hard drive and it worked fine. If you have lights flashing it probably isn't the power supply.
Posted on Oct 01, 2009
Testimonial: "Thanks. I'll do some research on how to check my hard drive"
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Jan 16, 2009 | Frigidaire Ovens
Computer power outage problem!
Your power supply is bad--you will need to replace it.
Jan 07, 2009 | Computers & Internet
Will not turn on.
bad power supply chang epower strip use monsyter clean power one clean up usa dirty power dont ever flip that switch in back to 215 u will fry it we use 120 115 in usa only ok
Jan 06, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP Pavilion a450n PC Desktop Logo
301 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
