Question about Fuji FinePix S2000hd Digital Camera
Broken latch on the door that holds the batteries in the camera
The door that holds the batteries in the camera has a broken latch, can I order a replacement door? The camera is Fujifilm S2000HD.
SOURCE: battery cover
I've taken out the screws and the front and back still don't come apart. It appears as though there are screws under the cover of the hot shoe, but they appear to be screwed in from the bottom of the flash shoe. any suggestions
Posted on Sep 09, 2008
  • 11 Answers
SOURCE: I am looking for a lens cap that will fit a Fuji Finepix S2000HD digital camera
let me just say that fuji sells the products but doesn't stock replacement parts.. i contacted fuji and they set me an email to call the 800 number. called and they refered me to another 800 number and then they in turn refered me back to the original 800 number. so if anyone is looking for a lens cap don't waste you're time.. they don't carry them..
Posted on May 30, 2009
  • 5 Answers
SOURCE: Fujifilm S1500 broken battery door
Yes, but you would most likely (don't quote me) have to send it back to the manufacture to get it fixed. That means $$$, is there a way for you to tape it on? You really only need the metal piece/plate touching the batteries.
Posted on Jul 26, 2009
  • 9 Answers
SOURCE: Fuji S5000 camera problem....The battery door will
Also see post:
http://www.fixya.com/support/t1747423-fuji_finepix_s5000_battery_door
OZwombat suggests a aluminum bar holding the battery door shut, attached to the case with a screw in the tripod connector
604foxtrot replaced half the camera case with that of a used (broken) camera
Elastics, tape etc does not work
Posted on Apr 07, 2010
  • 102366 Answers
SOURCE: Olympus stylus 1010 battery door latch broken
http://uscamera.com/vk9076.htm
Posted on Jun 14, 2010
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
The opening for the batteries is broken.
The 4 latches that the battery door locks onto is broke, you will need a different back cover and front cover.
Feb 26, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Fuji FinePix S2000hd Digital Camera Logo
52 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
