Question about Texas Instruments TI-89 Calculator
I keep getting undefined variable error when i try to graph
  • Texas Instru... Master
  • 8,016 Answers
The default variable for the integral is x. If you have a product between two litteral symbols the * must be inserted. Arguments of functions must be enclosed between parentheses. To avoid errors clear the variables before the integration: [2nd][F6:Clean Up] [2:NewProb][ENTER]ENTER]
Hope it helps.
Posted on Sep 30, 2009
Ti 84 plus wont graph
You might have used an inappropriate variable name.
For functional graphs y=F(x), the independent variable must be X
For parametric graphs, the independent variable in the x_t and y_t functions must be t.
For polar graphs the independent variable must be Theta, and for sequence graphs, it must be the special wiggly n.
Once you select the type of graph, the independent variable is entered by pressing the key marked X,T, Theta, n.
Dec 19, 2013 | Office Equipment & Supplies
Reset
You referenced a variable that is not currently defined. For example, you referenced a stat variable when there is no current calculation because a list has been edited, or you referenced a variable when the variable is not valid for the current calculation, such as a after Med-Med.
Jun 06, 2013 | Texas Instruments TI-83 Plus Calculator
Everytime I try to graph an equation my calculator says "error 14 undefined" i don't know how to fix it
Error 14 undefined may occur if you are referencing a variable that currently is not defined
Sep 12, 2011 | Texas Instruments TI-86 Calculator
Every time i try to graph a function "undefined variable" pops up on the screen and then i can't get anywhere after that
Do you have a function somewhere (not necessarily y1) that is attempting to graph. You can check this by going into the Var-Link menu (2nd MINUS) and searching for a function variable. If that doesn't work check the function you're trying to graph and see if it has a variable in it that is supposed to be a multiplication (xy instead of x*y) or if somehow the variable you meant to use got deleted
Aug 08, 2011 | Texas Instruments TI-89 Calculator
Want to graph simple functions , like y = x and get error message:" undefined variable".
From the alpha keyboard type in NewProb and press ENTER.
This will clear the contents of all the one-letter variables a-z.
Open the Y= editor and type in an expression for the function to draw.
You do not have to enter a multiplication sign between a numerical factor preceding the variable x and x. If a factor is a letter you must explicitly use the multiplication sign.
Press the key sequence to draw the graph.
Aug 01, 2011 | Texas Instruments TI-89 Calculator
Just bought this Ti-89 and I can't graph a Diff Eq. I followed the directions from the manual on page 69 and get an error: undefined variable
Even though implied multiplication is accepted generally by the calculator when it involves a number and variable, it leads to errors when it involves two sybmols,
xsin(x) is interpreted as a function called XSIN not X*SIN(X).
Suppose you have a function y1, function of t and you write ty1 the calculator will generate an undefined variable error: It reads ty1 as a variable.To prevent the error message you should write t*y1, showing the multiplication explicitly.
Similarly if you write y1'=0.001y1(100-t) the expression y1(100-t) is interpreted as a function call: the function y1 is called with argument 100-t. If it is what you want you should explicitly express the multiplication and wrtite y1'=0.001y1*(100-t).
Feb 01, 2010 | Texas Instruments TI-89 Calculator
I cannot plot graph in my Ti 89 graphing calculator
That means one (or more) of the variables you have in your function is not defined. Check to make sure you didn't misspell any variable name. Also, check to make sure you didn't run two variable names together. "ab" is the variable ab, not a times b.
Mar 19, 2009 | Texas Instruments TI-84 Plus Calculator
Can not display the graphs of functions
I have a manual in another language than English, so I do no know exactly or remotely what procedure you refer to, but I have recreated an instance where one gets the error you talk about. I give you the picts.8147bde.jpg When I enter [Diamond][Graph] I get the following message.
The graph independent variable is x by default, yet I entered cos(f). The calculator is expecting a function of x and I give it a function of some as other entity. Hence the error message. On the command line you cannot change the argument of Y1. It is x by default.
Hope it clarifies things.
Mar 11, 2009 | Texas Instruments TI-89 Calculator
Undefined variable
go to home and type Define x
Apr 13, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
1,072 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
