Question about Hotpoint WMA74 Front Load Washer
Does not spin
Drum does not spin at all but machine goes through full wash cycle including filling and emptying of water
  • iab Oct 01, 2009
    Found that brushes have worn through after turning machine upside down, Many thanks for help glassic7
    Much appreciated
  • 34 Answers
Either a belt or the motor brushes are shot.
Posted on Sep 30, 2009
Testimonial: "I have took top off and belt is fine, so hoping it is brushes and not something more serious. Have you any instructions for replacing brushes on this"
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Why won't Affinity fill or spin?
Probably there is water in the drum or the pressure switch is jam in a state of "full of water" or washing machine didn't drain water .. So, the fault should be sought in the elements responsible for control the level (pressure switch, pcb...etc.) or control draining water (drain pump, pcb, filter....etc.).
The precondition that the machine goes into a spin cycle is that pressure switch folded down to position "empty of water".
Dado
Jul 24, 2015 | Frigidaire ATF6000ES Front Load Washer
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Hotpoint washing machine
INSPECT THE BELT MAKTYBE BROKEN OR CAME OFF ??????????LET ME KNOW
Nov 29, 2008 | Samsung WF337AA Front Load Washer
Help
hi there,
sounds the pressure switch is not sensing the water level, so the machine thinks it's still filling. check the pressure switch and pressure switch cable. it's most likely just the cable itself. the pressure switch is located behind the drum and accessible through the back panel.
Oct 01, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint WMA74 Front Load Washer Logo
305 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
